andypalmer
- June 24, 2006
- Norfolk, United Kingdom
- '99 SOHC XLT
Hi there, I need help! Had a problem with idle and trouble codes for around a year now. I have:
P0171-too lean (B1)
P0172-too rich (B1)
P0174-too lean (B2)
P0175-too rich (B2)
P1131-O2 sensor indicates lean (B1)
P1151-O2 sensor indicates lean (B2).
The idle is crap and jumps about, once above 1000-1500 rpm all seems OK. The truck is converted to run on LPG (due to price advantages in the UK), it is a basic suction system connected to the air pipe with an emulator to loop good signals back to the PCM. It does use O2 sensor and TPS input to vary the LPG flow a little. The faults occur on both petrol and LPG.
I have done the following:
MAF sensor-cleaned and then replaced (new, genuine part)
IAC valve-cleaned and tested
TPS-replaced (new, genuine)
Spark plugs-replaced
Upper and lower intake manifold gaskets-replaced
Air filter-replaced (K&N panel)
Both upstream O2 sensors-replaced (new, genuine)
Cylinder compression test-OK
Check exhaust-OK
My local Ford dealer are telling me the PCM is next but before I waste more money I thought I would ask advice. Whatever I try next will probably be the last try before putting up with it, selling the truck or crashing the truck into a large tree! According to an LPG specialist in my area (these conversions are quite common in the UK) the PCM may have become corrupt due to the different burn characteristics/sensor inputs with LPG. They claim that when the PCM does a 60 day test it can modify some of its settings to suite what it finds (presumably originally to allow for engine aging) and that if running on LPG when it does this test the PCM has been known to change its base parameters to suite the LPG. As the LPG system is set up to mimic the petrol system the truck must work properly on petrol for this to happen, thus the problem. Does this make sense and does anyone have any advice? I have now spent over $2000 on repairs and mods and I am very rapidly coming to the end of my patience. I love this truck and don't really want to get rid of it.
Thanks for reading my rambling life story.
P0171-too lean (B1)
P0172-too rich (B1)
P0174-too lean (B2)
P0175-too rich (B2)
Check exhaust-OK
