sobo
- August 4, 2013
- So Cal
- 98 Explorer
Hi Guys,
Just picked up a 98 Eddie Bauer V6 SOHC. The temp gauge stays around the c and doesn't move much above it. I was reading around here and basically decided to change my thermostat. Do I have to remove the top and bottom housing or can I just remove the top housing and replace the thermostat and seal? Do I have to take off the top radiator hose for this? Also, is the drain plug hidden behind the fan shroud?
Thanks in advance.
Is there a chance it's not the thermostat too?
Thanks in advance.
