crazyflights
- August 31, 2008
- St. Joseph, MO
- 97 1 ton Jeep
I have a 98 Ford Explorer V8 with auto tranny, has 127xxx miles on it and I got it around 120,000 and was suppose to have rebuilt tranny in it, but what all was done to it and why it needed repaired -Im unsure? but did look clean so was out forsure, has drove fine
1st issue
-since I got it if your cruising in 4th/od maybe on slight incline at lower rpms, but want to accelerate hard to maybe pass somebody, when you smash throttle down, would sound like engine was reving rpms but tranny not responding, but then making almost a clunking sound when down shifted, heck maybe it didnt even down shift? I just avoid driving it like that, if you drive it easy never does that, or accelerate hard from lower gear all the way thru upper gears doesnt do it. -wasnt to worried rarely acted up,
But now 2nd issue maybe relate prolly not?
When your parked, in park, go to reverse has immediate response your in reverse, but go down to drive and has couple second hesitation before you feel it engage, even slighty have to rev it then feel engage and drives fine, but every so often if coasting and no load on it, when you put power back to it it feels like its not engaged, then kicks back in and drives fine.
Has clean fluid, proper level.
No codes?
Been reading alot, and will keep reading thread but wanted some help from anyone with thoughts,
So far from what I read maybe the Main pressure regulator Valve? Which Sonnax part # 76948-09 might help engagement?
thanks for all the help.
1st issue
No codes?
