M1998
- January 26, 2008
- Rosenberg, TX
- 1998 Mountaineer
I've read as many applicable posts as I could, but was hoping people in the know can sum up this Timing Chain Cover situation.
On the '98 5.0, if you've removed & replaced the timing chain cover gasket (due to coolant leaks or chain replacement) :
What did you do about the one piece oil pan gasket?
1. Were you able to use the oil pan gasket as it was in place ? (any leaks afterwards?)
2. Did you cut the one piece oil pan gasket & use those cork corners that come in the FelPro gasket kit? (any leaks afterwards?)
3. Did you (heaven forbid) pull the 5.0 just to change the pan gasket?
4. Or did you learn of some super secret gasket set or other trickery that worked really great.
I need to pull my timing chain cover to replace the gasket, but not before I have a plan in hand.
Thanks.
Thanks.
