99 4X4 Transmission lurch/stutter in high gear at low engine speed.
Wreckage
Edmonton, AB
99 Limited
My 99 Explorer AWD 5.0 liter has exhibits a transmission stutter when in high gear (overdrive) during acceleration from low engine speed. most prevalent at 40-45 mph with engine speed just below 1500 rpm. If I lightly press the accelerator pedal to accelerate without causing downshift, I feel a couple shudders. If I repeat the conditions but press the accelerator hard enough to cause a downshift, everything is smooth. Problem only occurs if I "lug" the engine when in overdrive. Most annoying when city driving and travelling up a slight grade at 40 mph.
Transmission oil was discolored. So I had a complete tranny fluid change performed at Ford. Problem is still present.
Any thoughts or am I looking at a transmission rebuild?
Sorry, but do not know the transmission model. Thanks for any and all responses
Kevlar7R
Phoenix, AZ
1997 Mountaineer 5.0 4x4
Mine just started doing the same thing. It was rebuilt 2 years ago. I'm interested in other responses. Mine seems to do it primarily when the tranny is cold. I hadn't checked my fluid yet, so I am interested to hear that you already did that.
Any thoughts?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
swetrid
Reading Pa
1999 Eddie Bauer
Ck plugs and wires, they are usual suspect with those symptoms.
ragajungle
Chicago, IL
89 BroncoII & 05 Taurus
I used trans tune from Seafoam on a 97 awd 5.0L and it helped the torque converter shudder immensely. - if in fact that is what is making it shudder. x2 on plugs and wires.
Kevlar7R
Phoenix, AZ
I did plugs and wires, plus a PCV valve and Seafoam treatment (engine) and the issue is gone. Good call on plugs and wires.
swetrid
Reading Pa
1999 Eddie Bauer
Thanks, ran into same thing day I bought mine on the drive home and was spark plugs. They were original at 124000 miles.
CJL
2000 AWD Ex
Mine does this,glad to hear the fix is minor.
What exactly makes the truck studder? Not enough spark under load?
CJL
2000 AWD Ex
Just thought id post that plugs and wires fixed my studder problem also,Thanks guys!
Wreckage
Edmonton, AB
99 Limited
Changed the plugs and the shudder is gone. Thanks for the help.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
blueka
Elite Pickler
Location
Liverpool
UK
97 UK XLT, 99 Sport V8,
I think you should drive it to Saskatoon and give it to me.... I'll give you back what I don't use after I've shoved the 5.0 in my sport... ;)
Si
minimac
bealeton va
01 XLT old body style
When you say Ck plugs and wires, do you mean spark plugs and spark plug wires? My '01 XLT has made a lurch a few times when in overdrive, going up a hill or something. the plugs in it now have about 70k on them.
This is my first post, as being a member for awhile now i have never needed to post anything. this Forum is amazing! i spend hours on here...
sport97
Elite Procrastinator
connellsville pa
1997 sport SOHC 4.0
Plugs and wires didn't do it here.
I believe that sounds like torque converter issues. Atleast thats what I think I have...
