eupleili
- August 25, 2009
- North Ridgeville, Ohio
- 99' XLS
Hey there,
This is my first post so I hope that I can get some answers. I have used this forum to fix a number of things on my X and there seems like a never ending list of things that still need to be done. It only has 75k miles on it and I just cant seem to get it to run right. I have three major problems right now that I would love some insight on:
1. I have a very rough idle/cruise at coasting speeds. I have recently replaced my DPFE sensor because it was "torched" by a loose vaccum hose. It ran fine for two weeks and the Check Engine Light actually stayed off for those two weeks. Then all of the sudden the light came back on and the rough running has been getting worse and a sulfer "rotten egg" smell has started. I have read that it could be the cat but more likely the EGR system.
2. I have never really had the type of power/excelleration that I thought would come from this vehicle. I have driven other vehicles of this year and even earlier that have a nice smooth and powerful excelleration. Mine is rough and revs the rpm's before the tranny shifts to a lower gear and even then it just seems loud and rough never smooth.
3. The third problem might be an extension of the 2nd or the culprit. It seems that when the truck gets to around 2.5 rpm's the engine revs verry high. I have planned to change the transmission fluid, filter and gasket soon but I don't know if the problem might run deeper than that.
This weekend I plan to do minor tune-up maintenance such as replace the fuel filter, pcv valve, oil change, and other minor things. I have recently changed all of the plugs, dpfe filter, and the vaccum lines that come from this. I have a full mechanics garage at my disposal and correct mechanical supervision to do all the work I need done I just need some push in the right direction. Thanks in advance for the help and hopefully I can make this beast last for me for another couple years.
