Thallarsen
- February 21, 2000
- Potomac, Maryland
- '99 5.0 Limited AWD
The CV is toast in my front driveshaft. Since the clicking was clearly the sound that a bad CV makes, and it was reverberating through my front driver's side wheel, I thought for sure it was a bad driver's side CV axle.
After replacing the CV axle, the sound persisted.
Got it up on 4 jack stands and let it idle in gear. "Click click click" was reverberating through my front driveshaft...so off it came.
The shaft CV grease boot is completely torn and the CV joint is sloppy.
I can't be too pissed....250k on the truck.
So what are my options for replacing this front shaft CV?
NAPA lists complete front driveshafts (p/n NMD 931111 or NMD 931112).
I assume that the CV isn't serviceable & therefore replacing the shaft as a complete unit is the only option.
...or are there options other than replacing the entire front shaft.
If not, is $300 the best price I'm going to find?
Thanks..
Thanks..
