99 exploreer trans issue
hjthaboss2020
Lampasas, Texas
99 explorer eddie bauer
so i went to pull out of my driver the other morning and as I was pulling out I felt a pop, now the truck acts like its constantly in neutral really need some help seeing how I don't really have any money to put into it right now. its a 99 Explorer 4.0 SOHC with an automatic trans. odometer says 265000 miles...
974X4BLACKSPORT
Location
FL
hudson
BLACK 1997 SPORT 4 BY 4
From your description, sounds like something broke inside the transmission or torque converter, no way to tell what it is without taking it apart, or at least without a thorough on site vehicle inspection.
First thing to check would be the hydraulic operating pressures.
G 4R70W Trans shutter Transmissions & Transfer Cases 2
08EddieCA 2008 Torque Converter compatible with 2003 Automatic Trans Transmissions & Transfer Cases 2
1 1998 Ford Explorer Manual Trans: Bleeding Master & Slave Transmissions & Transfer Cases 2
T Minor trans work, now almost stalls in gear Transmissions & Transfer Cases 2
imp Auto Trans. "Glitch"? Transmissions & Transfer Cases 9
G Various little 4R70 Trans issues Transmissions & Transfer Cases 36
B 2000 Explorer trans slips in reverse Transmissions & Transfer Cases 15
P 2007 explorer trans pan with dipstick Transmissions & Transfer Cases 2
P 2006 5r55s trans swap Transmissions & Transfer Cases 1
gmanpaint P1309 code & OD stuck on, after engine/trans swap to OBDII OS Transmissions & Transfer Cases 40
M Trans code P0741 more questions, but learning Transmissions & Transfer Cases 5
C 1992 Auto Trans Downshifts Transmissions & Transfer Cases 0
K Raptor trans in an Ex Sport Transmissions & Transfer Cases 2
A P0741 8 years after trans rebuild to fix 2-3 flare. Transmissions & Transfer Cases 1
D explorer trans to ranger -interchange? Transmissions & Transfer Cases 0
S 03 explorer trans Transmissions & Transfer Cases 3
M Changing trans fluid on a 2006 XLT, not recommended? Transmissions & Transfer Cases 3
B Trans appears to freewheel downhill while in First Gear Transmissions & Transfer Cases 1
K trans cooler install Transmissions & Transfer Cases 0
T 5.0 Explorer trans problem after swap. Transmissions & Transfer Cases 12
G Trans swap into 99 Explorer from Ranger Transmissions & Transfer Cases 2
V Trans swap 99 EB to 98 EB no gears. Transmissions & Transfer Cases 14
M Trans valve Transmissions & Transfer Cases 3
08EddieCA New Front Pump 5R55S = must the trans be vertical to install the new pump Transmissions & Transfer Cases 5
S 6-speed trans OD lockout Transmissions & Transfer Cases 1
A A different approach to stuffing clutch packs in the A4LD, 4R, or 5R Trans Transmissions & Transfer Cases 7
mounty71 5.0 Trans Fluid Flow Direction Through Radiator Transmissions & Transfer Cases 15
M Trans when hot? Transmissions & Transfer Cases 4
S 94 explorer trans swap question Transmissions & Transfer Cases 5
08EddieCA Issue with Neutral Safety Switch - not aligning after trans rebuilt Transmissions & Transfer Cases 14
G Trans problems Transmissions & Transfer Cases 3
B Will a trans from a 98 4x4 work in a 96 4x4 explorer Transmissions & Transfer Cases 14
G 96 4.0 Leaking Trans Fluid between Engine and Transmission Transmissions & Transfer Cases 3
I 1996 4.0 explorer trans problem Transmissions & Transfer Cases 4
P 5r55e trans problems Transmissions & Transfer Cases 3
D '91 EB 4X4 Trans Transmissions & Transfer Cases 2
P 98 explorer trans issues Transmissions & Transfer Cases 5
M after trans swap, won't move forward Transmissions & Transfer Cases 3
B '96 Ranger w/4.0 4x4, Manual Trans R&R Imminent Transmissions & Transfer Cases 5
A Raging at Trans Mechanic Transmissions & Transfer Cases 6
ProjectAviator 5r55e trans capable of going into first manually? Transmissions & Transfer Cases 4
P 99 exp. sport trans. slip Transmissions & Transfer Cases 0
M 1997 B2300 auto trans help! Transmissions & Transfer Cases 2
PODHokie 5R55E Trans - RPM's constant, speed increasing Transmissions & Transfer Cases 2
Birdy 98 5.0 trans in a 97 Transmissions & Transfer Cases 14
gmanpaint Loud squeal coming from trans when placed in gear! Transmissions & Transfer Cases 2
J 02 eb explorer 4.6l 4x2 trans error 5r55w Transmissions & Transfer Cases 0
S 2005 Ford Explorer Trans Problems Transmissions & Transfer Cases 0
O 2003 Ford Explorer Trans and Solenoid Transmissions & Transfer Cases 1
W A4LD Trans fluid change help Transmissions & Transfer Cases 3
Similar threads
