  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
99 Explorer Auto Shift lever problems
ju1cy
Bowling Green, KY
1999 Ford Explorer 4x4
Last Friday on the way home from work I noticed my shift lever was extremely hard to use but I didn't have any issues other than that. Yesterday I go to leave for work and now it wont start. I knew it wasn't a battery issue but I left in my wifes car as I suspected the shift lever to be the culprit. When I got home I jammed the shift lever toward park and was able to get it to start and run. I hopped on here and read the threads regarding the loose bolt on the bracket. I checked the bolts earlier and they are both solid where they should be. My issue sounds a slightly bit different. When this problem started the gear level was extremely hard to maneuver from position to position. When in (p) it is in Reverse. I've taken the bottom of the steering wheel off and the metal plate behind it. When I move the lever I can see the tiny thread cable pull the lever. I can see the bracket rotate and connect parts also seem to move. I was wiggling the shifter gently with the keys engaged and the break pressed while doing my visual check and after around a minute of gentle moving something popped. Everything that I can see at this point looks fine but the gear shifter has changed it's behavior now. Now Park to Reverse and visa versa is still extremely hard. Every other position is reached with 0 to little resistance and the reverse indicator lights seem to be stuck on in all positions. Any ideas?
ju1cy
Bowling Green, KY
Found the problem, or at least part of it. The shift lever cable is broken under the car about 5 inches from the eyelet that connects to the transmission. I'm guessing something was jammed up and my fiddling with the shifter broke the cable (that would be the point where I felt something let go). So the cable has broke very close to the end of the cable, and there are some adapting pieces that look to be capable of disconnecting and replacing small sections of the cable. If possible I'd like to just replace the end if that is doable. Can anyone confirm if that cable can be replaced at the end? Will have pictures later today when I get home.
ju1cy
Bowling Green, KY
This is a picture of a stock photo that is exactly what I have. The end eyelet broke off somewhere in that shaft (it pulled out and the braided steel is broke). Can it be disconnected somewhere in those connectors prior to the braided cabling on the right?
albi1cnobi1
Elite Mountaineer
South Jersey
99 Mountaineer V6 4x4
No, it is a 1 piece cable. If the cable itself broke you'll need the whole thing. It's not that big of a job to replace, the hardest part is attaching it under the dash.
ju1cy
Bowling Green, KY
That's what I was thinking. Thanks for the info. Having a hard time finding the cable locally (2/2 scrap yards where 0 help).
albi1cnobi1
Elite Mountaineer
South Jersey
Hope you find it. karl(kbabiak) is pretty good with parts, he's always come through for me. Ships quick too. If he can't help you try ped5stang, he's a vendor here as well. You could also try posting in the classified under "parts wanted", you might get some hits there also.
ju1cy
Bowling Green, KY
Dealer has is for nearly double what it is on eBay. Now I have to decide between spending the extra $60 or waiting. I actually wrote on Kbabiak's parts post per the recommendation I received via PM. Thanks for the help.
ju1cy
Bowling Green, KY
Got the part from the Dealer @ around 450% of Kbabiak (had to get my Explorer going so I could stop stranding my wife at home). Installation was fairly simple and it is running again. Thanks for all the help.
S Shift Lever adjustments 98 Explorer Auto. Stock 1995 - 2001 Explorers 2
F 1999 explorer 4x4 auto trans problem/166k miles Stock 1995 - 2001 Explorers 3
P 2000 explorer xlt v6 auto won’t move Stock 1995 - 2001 Explorers 11
allmyEXes 1997 Explorer 4.0 Auto Trans rebuild 2WD Stock 1995 - 2001 Explorers 0
W 1999 explorer auto four wheel drive won't disengage Stock 1995 - 2001 Explorers 8
M 1997 Explorer - auto transmission fluid Stock 1995 - 2001 Explorers 11
S 98 Explorer XLT- Auto Headlamps Not Working Stock 1995 - 2001 Explorers 5
J 2000 Explorer - Auto Trans Shifter - No Longer Close to Steering Wheel Stock 1995 - 2001 Explorers 0
J 1998 Explorer 4.0 Auto blowing fluid from vent Stock 1995 - 2001 Explorers 5
T 96 4.0 explorer xlt auto awd Stock 1995 - 2001 Explorers 7
T 1995 Explorer 4wd front end shakes a lot when in auto 4wd mode Stock 1995 - 2001 Explorers 2
C 98-01 Explorer auto headlamp sensor adjustment Stock 1995 - 2001 Explorers 7
A 95 explorer auto trans wiring harness diagram Stock 1995 - 2001 Explorers 2
C Where to buy a pre 1999 5.0 V8 Explorer engine+auto trans only Stock 1995 - 2001 Explorers 8
J How does the AUTO button work in a 4x4 Ford Explorer? Stock 1995 - 2001 Explorers 7
A 1999 Explorer 4WD Auto issues Stock 1995 - 2001 Explorers 2
F 2000 Explorer XLT auto A4WD problem Stock 1995 - 2001 Explorers 5
A 99 Ranger 4.0 auto to 99 Explorer 4.0 5 spd swap? Stock 1995 - 2001 Explorers 0
D 1999 explorer auto shifting problem Stock 1995 - 2001 Explorers 1
J 99 explorer auto temp control problem Stock 1995 - 2001 Explorers 2
L 2000 Explorer XLT SOHC 4x4 auto has no first gear Stock 1995 - 2001 Explorers 1
F 1999 Explorer Auto V6 4.0L OHC Vin E Speed Sensor interchange years Stock 1995 - 2001 Explorers 0
H 1997 Explorer 4.0 Auto Trans ? Stock 1995 - 2001 Explorers 4
D O/D light blinking on 1995 4wd Explorer 4.0 ohv auto. Stock 1995 - 2001 Explorers 16
S O/D off light flashing / weird shifting - 98 auto Ford Explorer Eddie bauer Stock 1995 - 2001 Explorers 9
F 95 Explorer - 4 Auto not engaging, 4 low is. Stock 1995 - 2001 Explorers 2
D 2001 Ford Explorer Sport Auto RPMs? Stock 1995 - 2001 Explorers 5
S Explorer Overhead & Auto Mirror Stock 1995 - 2001 Explorers 4
D Explorer 97 LTD auto electricals...HELP Stock 1995 - 2001 Explorers 4
G Purchasing decision - 1998 Explorer Sport (Auto) Stock 1995 - 2001 Explorers 8
F Problems with Auto 4x4 for 97 Explorer Sport Stock 1995 - 2001 Explorers 1
D Ford Explorer 4x4 auto system, how does it work? Stock 1995 - 2001 Explorers 28
L 97 explorer Auto door locks Stock 1995 - 2001 Explorers 7
S New guy with 95 Explorer auto trans question Stock 1995 - 2001 Explorers 5
M 96 Explorer 4WD Auto Stock 1995 - 2001 Explorers 1
S Reverse busted in my 99 Explorer Sport SOHC Auto.. Stock 1995 - 2001 Explorers 14
R 2000 Ford Explorer XLS auto 4x4 will not disengage Stock 1995 - 2001 Explorers 12
L O/D off light flashing in 99 Ford Explorer. Stock 1995 - 2001 Explorers 6
M ECT replacement 1996 Explorer 4.0 OHV Stock 1995 - 2001 Explorers 1
N 1996 Explorer Sport 4.0L OHV Camshaft syncronizer positioning Stock 1995 - 2001 Explorers 8
K 96 Explorer fuel pump not activating Stock 1995 - 2001 Explorers 2
S Is a 1998 Explorer Limited 5.0 Full Time 4WD w/transfer case towable behind an RV with all four wheels down? Stock 1995 - 2001 Explorers 1
G My Explorer does not sit right Stock 1995 - 2001 Explorers 4
C ABS Warning Light on Explorer Stock 1995 - 2001 Explorers 0
F Switch from 5w30 to 5w20 in the Explorer - Tech Service Bulletin Stock 1995 - 2001 Explorers 35
S 1. Both Differential Oil changes plus Transfer Case, Transmission Oil Service 1998 EXPLORER LIMITED 5.0, 4 door, air suspension, AWD, Stock 1995 - 2001 Explorers 20
D 2000 Explorer 5.0 AWD Electrical Question Stock 1995 - 2001 Explorers 2
4pointslow My 2000 Explorer 4 door XLT Stock 1995 - 2001 Explorers 31
M Compatibility of 2nd Generation Explorer Limited Options with XLT Stock 1995 - 2001 Explorers 3
T 1996 explorer 4.0 ohv Stock 1995 - 2001 Explorers 4
Similar threads
