"They are speed-controlled based on the pressure at the fuel rail. Pressure drops, more demand for fuel, PCM speeds up the pump. Actually, that is going on constantly, pump speed varying all the time to provide constant
pressure at the rail."
Interesting information here I was not aware of. How exactly does the PCM speed up and slow down the pump? I would assume by varying voltage? We had return less fuel rails in 1998-2003 also, I do not think the PCM slows or speeds up these pumps? as the power to the pump comes from a relay?
First I have heard of the 04+ style return less fuel doing this
@410Fortune
Good points! First one must understand that pumps are "constant volume" devices. That means each pump revolution moves "X"-amount of liquid, no matter what, since liquids are incompressible. In hydraulic systems, it's customary to size the pump volume slightly larger than the greatest anticipated need: therefore, there is always "excess" fluid being moved, part goes to do desired work, the remainder is "dumped" back to the tank by a relief valve. Moving that extra fluid uses energy and creates heat, but is necessary by usual design methods.
Since D.C. motors are easily speed-controlled, today's returnless fuel systems have a specialized sensor mounted on the fuel rail called the "Fuel Pressure and Temperature Sensor." It constantly feeds a signal to the PCM, which detects changes in pressure: the fuel pump's speed is being constantly controlled to maintain a narrow band of fuel pressure, regardless of engine demand. Sudden open throttle instantly bumps up pump speed to keep pressure constant, and vice-versa, so no effort is wasted pumping fuel back to the tank. All fuel delivered by the pump gets burned in the engine, IOW.
Ford Engineers think of a lot of scenerios. What if the FPTS fails? Pump stops, vehicle stalls. They foresaw the possibility, and programmed-in a default which makes fuel pump run at maximum speed, lots of lights and whistles warn the driver, vehicle operates very inefficiently, even making some black smoke, but doesn't quit running. The pump has a built-in relief valve which I have heard dumps excess fuel right back into tank at about 100 psi. Under normal conditions, that relief is always closed.
'98 to '03 system you mention I have only fuzzy knowledge of. I believe they had a Fuel Pump Control Module which was eliminated in 2004, that actually did vary the pump speed, but not as accurately as desired, until the FPTS was added. Many threads exists about corroded FPCMs, leading me to believe they were electromechanical devices, rather than electronic alone. Quick search was fruitless. Several years ago I got the code for Fuel Rail Pressure & Temperature Sensor, knew only that it was used to run the pump, imagined crapping-out along the road. Bought and installed a new sensor, never had any running symptoms with the bad one......Learned later of the fail-safe pump set-up. I'll try to find more on '98-'03 returnless.
(whew!). imp
