I've got a 99 Explorer with the SOHC 4.0 V6 that has developed a hard start. Had a CEL that was coming back as lean operation on both banks. Hooked the fuel pressure gauge to it, and saw I had pretty low pressure (40-ish psi), and it would drop back to 0psi within 5 seconds after shutting it off. So, I replaced the pump and that brought the pressure up to 63 psi.
The CEL is gone, and the truck runs better now, but it still has the hard start. Pressure is still dropping to 0 psi within seconds after turning the engine off. So, I'm thinking I've got a bad FPR or leaky injector(s). On the 99 SOHC, where is the FPR? Haynes shows it by the rail, but it's not there. Of course, Haynes usually generalizes a bit too much and tries to cover too many models/years in one fell swoop. Is there any way to test whether I've got leaky injectors vs. a bad FPR?
