Jaimec
- June 22, 2013
- 1999 Explorer
I'm new here, but I'll try to keep it short.
I've been looking at buying an Explorer for over 2 years, and have done my due diligence, to the best of my ability. I have been lurking on several forums, as well as googling potential problems for various years, as well as the repairs involved.
So, here's the deal.
I found a 99 Explorer (supposedly an XLT, but the body doesn't say that, and the trim package doesn't support the claim, other than alloy wheels....have yet to see the title, so I don't know). The price was great, HOWEVER, it was throwing a couple of codes.....P0171, and PO174. Both banks too lean. My first thought was MAF.
Took it back to the dealer and they were miffed. Turned out the Check Engine Light wasn't working, either The mechanic thought it was the MAF, as well, and cleaned it (I've learned that this doesn't always work). So................I spent 6 hours at the dealership, driving, stopping, and then re-checking the OBDII readings, to see if all sensors had reset. All the while, the salesman assured me that they would get it through emissions, which is the biggest issue for me. I have no reason to distrust the guy, other than he's a used car salesman, which is EVERY reason to distrust him.
So...the results:
1-Initially, I was getting P0171 and P0174 readings.
2-Later that night, after 6 drive cycles, it was still trying to read the codes, with the 'C' flashing and a yellow light.
3-Tonight, it throws the same P0171/P0174 codes, but the 'C' code is solid, and not flashing.
Soooo.....that tells my uneducated mind that.... there was a prior issue with it throwing P0171/P0174 (too lean on both banks), so when reset, it threw no codes until everything had reset itself. BUT....that was when the 'C' code (catalyst) came about. So, once again, I think it has to be related to the catalytic convertor(s), or their sensors, right???? Or O/2 sensors??? Crap, I don't know.
I really like this rig, and want to keep it, but can't afford a lengthy stretch of expensive repairs. Any help would be GREATLY appreciated!
Jaime
So...the results:
Jaime
