Thallarsen
- February 21, 2000
- Potomac, Maryland
- '99 5.0 Limited AWD
The motor is running fine, no grinding or crunching....the antenna just won't go down.
I assume it's a broken mast/plastic-toothed strip.
Looks like there's a difference between the '98/earlier & '99/later.
Any idea where I can order a replacement mast for a '99 on line?
Can it be replaced from above the fender, or does the whole power unit need to be pulled?
Thanks,
J.P.
Thanks,
J.P.
