Pics
Ok I emailed James and provided in detail the whole dealio with mods and iat related stuff.
Ok so my 90mm maf is missing the outside wires for the IAT. They are the solid gray and gray/red. So Don, you just spliced in a "stand alone" Ford sensor. I kinda rather go to the junkyard cause I know there are some older explorer's there with these, plus I'd like to get both plug ends, not just the sensor end. Junkyard is only 10min away on my parts ***** aka bike
the maf plug on my '99....
So on to the many pics...
Here is the Painless fuse block I got for oil pump and gauges. It has two ignition hot points and one always hot. This model is good for 20amps per point. I wired the signal to the radio because my fuel pump fuse is always hot for some reason.
wires are bit out place for now.
Here is what I did for the pcv. I got a brake booster check valve from Autozone. It came with two grommets. I glued one to the other and stuck it in the valve cover after removing the existing pcv valve grommet. The valve opens nicely under vacuum and pressure. I had to cut a little off that big plug mount to clear. Also I put clamps on everything. Good thing I always grab as many I can fit in my pockets at the junkyard.
Injectors with adapters. No clearance issues.
Intake tube support wrapped in electrical tape to keep things soft.
Holset WH1C rebuilt and cleaned/painted.
Oiling. There is the oil block with factory sender and oil feed with check valve that Don recommended. Oiling system works great btw. All 1/4" braided to the turbo, then 3/8" braided to oil pump, then 3/8" rubber to 5/8" filler neck.
The loop is there because I am not 100% on oil pump location yet.
Charge piping to inter-cooler. I wrapped the tube in aluminum tape because the tubing is not abrasion resistant at all. I put some extra gasket material and fiberglass tape on areas where things are in contact. It may appear to hang down some but no piping is below the trans cross member. The turbo is the lowest point at about 1-2" below trans mount. That's as high as I could get the turbo. I could go a tad higher if I removed the wastegate, which I might do. Not sure how one would do this with 4x4.
Turbo mount and y-pipe to turbo.
I had a 45 silicone that I couldnt use so I crammed it on the exhaust side to keep stuff from plastering my oil pump and frame. Going to have to make an exhaust somehow. It's too loud.
I'll get pics of the bov up maybe tmrw. I'm burnt out on it for the time being. Still need to hook up boost gauge, acquire IAT sensor and tuning software. Only code is still P0113 for no IAT input after 10mi of driving. I think getting that sensor in will help driveablilty and fix my high hanging idle.
