Motolz
- November 3, 2019
- Atlanta
- 1999 Explorer Sport
So I have a wonderful 99 Explorer Sport that never quits.. until now... I have a 'crank wont start' issue that I can pin point an issue, but need an answer.
1) I swapped the relays... still won't start.
2) After sitting over night, I pushed the Fuel Pump schrader valve and nothing came out
3) I turned the key and depressed the valve and I do have pressure.
4) I tried to start and it started right up!
5) Turned off and restarted several times.. no problem
6) let sit for 30 minutes.... would not start..crank no start
7) key on..pressed the schrader valve... I have pressure
8) tried to start..started right up!!
So bottom line, If I 'prime' the line' by depressing the valve with the key on, it starts. Seems like some kind of vacuum issue or something. Anyone experience this and resolve?
Thanks all! 200k and still running... well mostly!
Motolz
Motolz
