TOMC
- August 20, 2005
- Tucson AZ
- 99 XLT
I live in the desert. it is hot hot hot.
The AC on my Explorer is usually set on MAX which recirculates the air within the vehicle. Lately I have noticed that when I am accelerating hard, Or on a long steep uphill grade, The A/C quits blowing air out of the vents. I can still hear the fan running.
As soon as the load on the engine is over the A/C returns to normal.
I realize that this is a vacuum actuated damper problem. My explorer has 67,000 miles and the V6 SOHC engine runs strong. I have looked for vacuum leaks on the engine without finding anything. The power brakes are not affected. The engine vacuum is good, but I can't put enough load on the engine in my garage to make anything happen to the A/C.
I suspect that there is a small vacuum leak on the A/C control itself which only affects the A/C dampers when engine vacuum is down during open throttle situations.
Has anyone experienced this? Is there anything that I may have missed?
You have a great forum here, thanks
