A/C causing rough idle & elec. problems
ryster
Southeastern, PA
2011 Hyundai Sonata GLS
Hi!
My parents are having an odd problem with their '00 Mountaineer (4WD, 4.0LSOHC, 15K miles). Thought maybe someone could offer some ideas.
Occasionally while driving with the A/C (auto A/C) on, the truck's timing will start to flutter. It feels like you are driving on a rough road. As you come to a stop, the idle will drop to around 500 and the truck will feel like it wants to die. After about 15 or so seconds of stopping, the idle will even out slightly but still be about 600-650 or so. All of this only happens when the A/C is on and the engine is at full operating temperature. The dealer could not reproduce the problem, but replaced the MAF sensor under warranty. It didn't solve the problem.
Similarly, we noticed that the automatic headlights did not come on when we pulled into the garage today (my Mom had me drive the truck yesterday to see if I could reproduce the idle problem). Normally the headlights will kick on when entering the garage. So, in an attempt to troubleshoot the lights I was going to shut the truck down and restart it. While the truck was still running, I started shutting off all of the accessories. As soon as I turned the A/C off, the auto headlights came on. Very odd...
Do you think it is possible the A/C is causing some sort of problem with the electrical system? It is obviously interfering with the auto headlights, but I am also thinking it is affecting the engine timing/idle problems as well. It is just interesting the problems don't surface when the A/C isn't being used.
Thanks for your help!
mrboyle
I Drive By Brail
Moderator Emeritus
Montrose, CO
'95 Bronco '80 Toy
It sounds to me like a good possibility that there is some kind of electrical problem related to the A/C control system. If the turck is still under warranty I would take it back to the dealer and show the service writer exactly what you found. If they still claim that they can't locate the problem try another dealership. I haven't done much work on the newer X's and Mounts, yet (most are still under warranty) so I can't realy help much.
01EB5.0
Allendale, MI
2001 Eddie Bauer V-8 AWD
Ity soulds to me to be unrelated. The headlights take a few mins to come on. they don't come on instantly because then if you drive thru a shady area or a bridge or the like, everyone's headlights would go on and off and stuff. I think your problem is strictly the A/C not cycling as it should. The compressor should go on and off so as to not make the engine die. Mine does anyway...open the hood and let it idle. watch the A/C compressor to see if it cycles. If thats not the problerm just bring it in under warentere.
TPLYNCH
Brewster, NY
1999 XLS
You may have a problem with the Idle Air Control valve. That is what is supposed to kick up RPM's when the A/C causes a drag on the engine. Sounds to me like it is not doing it. Search for IAC.... There are many threads regarding this item.
L What's causing this.... Under the Hood 1
B jet chip causing suspension light Under the Hood 0
E Part identification, could be causing a squeak? Under the Hood 1
S Snow tires and wheels causing vibration Under the Hood 4
M What is causing my water pump shaft to leak? Under the Hood 7
96 Explorer XLT Whats causing little spudder and slugish driving-Coil ?? Under the Hood 0
M cam swap causing headache Under the Hood 9
D What could be causing this power steering noise? Under the Hood 3
9 Bad front driveshaft causing shudder??? see pic inside Under the Hood 2
B What could be causing this Under the Hood 0
T UPDATE: Missing/bucking -- something causing plug wear Under the Hood 6
T Bad gas cap causing check engine light? Under the Hood 8
D What is causing this occasional clicking/ticking sound ? Under the Hood 3
M K & N causing problems, need input.... Under the Hood 54
gavin Superchips Micro Tuners causing problems? Under the Hood 1
L Loose speedo needle, causing surging cruise control Under the Hood 3
B What could be causing my ex to all of a sudden run rich Under the Hood 8
F What is causing this noise? Under the Hood 3
F 1998 Ranger 3.0 starts rough runs great Under the Hood 0
K 2006 Mounty 4.0L Rough idle Under the Hood 1
K Engine Knocking, Rough Idle, Misfire? Video Under the Hood 1
D ROUGH IDLE/HESITATION Under the Hood 0
C Rough downshift and upshift Under the Hood 0
D Running extremely rough Under the Hood 4
L Rough start Under the Hood 0
C 2005 Explorer rough idle after changing serpentine belt... Under the Hood 1
L Warm engine shudders and runs rough at startup. Under the Hood 21
J 2000 4.0 SOHC rough idle after rebuild Under the Hood 1
C Unsolvable Explorer Rough Idle. Any OBD II experts? Under the Hood 219
K 2015 Explorer runs rough Under the Hood 0
S Mountaineer Running Rough As Can Be Under the Hood 0
N 2000 xlt explorer running rough Under the Hood 1
T 2003 Ranger 4.0L runs rough low/high idle. no codes Under the Hood 0
B 04 Explorer 2wd Rough Idle no Check Engine lights Under the Hood 0
T 98 Explorer SOHC Rough Idle and Mid-speed Hesitation Under the Hood 6
H rough running 5.o 99 mountaineer Under the Hood 1
9 4.0L SOHC misfire cylinder 1 and rough idle Under the Hood 1
Kirby N. Hard Start/ Rough Idle on Start Under the Hood 24
F Rough Idle, Check engine light Under the Hood 2
I Rough idle, jumpy engine Under the Hood 1
M 2001 Explorer V6 SOHC rough idle driving me crazy! Under the Hood 9
D Rough idle 1998 Ferd Exploder XLT SOHC E vin Under the Hood 0
B 1999 V6 SOHC p0174 p0171 "sneeze sound" and rough idle Under the Hood 2
D '03 Sport rough idle Under the Hood 3
B Rough Idle/ Sputtering on '06 V8 Limited Under the Hood 13
M Unusual Rough Idle Under the Hood 2
rpenner54 Running rough in Wichita Under the Hood 12
S rough idle, loss of power under acceleration Under the Hood 6
1 Rough idle and code po304 Under the Hood 5
A Rough idle, cut off, etc. Under the Hood 2
Similar threads
