- January 27, 2002
- Texarkana AR/TX
- 94 SAS sport
96 model 5 liter, 134a
I have the gauge on the low side, ran air for 3 minutes on max/high and im showing 35psi. The gauge shows this to be right in the middle of "filled" 25-45 being normal. My air never blows cold anymore... just kinda "cool". Should i go ahead and charge it to the full 45psi?
From what i understand, the pressure readings are not accurate do to ambient temperature. In other words, its 100 degrees right now and HAWT outside. Could this mean that my 35lb. reading is really a little low? In other words.... if it were 70 degrees outside instead of 100+ would my reading be closer to 25lbs?
