A/C Clutch Bearing Replacement
koda2000
x
I've noticed that I sometimes hear a noise that seems to be emanating from the A/C clutch pulley on my 2000 Mountaineer 5.0. When I first got the truck I replaced the serpentine belt, as the old belt was worn and glazed (I think it was the original belt w/180K on it). Replacing the belt with a good quality one got rid of a lot of the under-hood noise, but I've noticed that sometimes the A/C clutch will have a little squeak. It actually only does it when the A/C is OFF. I'm thinking it's probably the clutch bearing. BTW, the A/C works great.
Has anyone changed one of this bearings? I see RockAuto lists one for about $20. I'd like to know what's involved with doing this job. I assume I'll need some kind of special tool to hold/remove the clutch and pulley. Can I borrow the tool I'll need from the auto parts store, or is it too specialized?. Can I replace the bearing w/out removing the compressor from the truck? I have access to a press, as I assume this will be needed. -Thanks
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
A/C Clutch Removal
The front of the compressor reveals the clutch plate, which turns the compressor itself. You can turn this plate with your fingers, and feel the drag of the compressor internals. The magnetic clutch lies behind the front plate, and contains the bearing you suspect of being noisy. You can rotate the clutch and pulley assembly with your fingers after removing the drive belt. That might reveal a feeling of harshness in the bearing, but doubtful you can spin it fast enough to squeal.
Removal of the clutch plate involves holding the plate stationary to loosen the center nut, which clamps the plate to the compressor shaft. The 3 upraised "bumps" visible are used to hold the plate from rotating, by placing a tool having 3 holes, larger than these bumps, which fit over them, a round center hole to access the nut, and a square hole to introduce a ratchet wrench or breaker bar. Such a tool could be made of 1/4 inch thick plate, aluminum would work nicely. The Ford Special Tool part number is T94P-19703-AH
The A/C clutch pulley is removed next, using a bearing puller having sufficiently wide jaws to encompass the O.D. Use only hand wrenching, no impact tools! The Ford Special Tool part number for a puller whch fits is D80L-1002-L
Ford Shop Manual does not detail further disassembly, as in seal replacement. Evidently, the bearing is pressed or fitted into the pulley, and may not be separately serviced, similar to those bearings found in idler pulleys.
Hope this info helps you! imp
Texan01
Dallas, TX
1995 Explorer XLT
I've replaced mine a few times, the hardest part is getting the bolt off. Once thats off, a thin screwdriver to work the plate back and forth a bit to get the clutch face off.
a big snap-ring holds the pulley bearing on, and its almost a press-fit, you can work it off without a puller if you have some patience. I used a prybar at the junkyard to get one off, on mine it nearly fell off on its own.
koda2000
x
well, never yet met a bolt i couldn't get off. thanks guys.
W M5OD Clutch Release Bearing Replacement Hint... Stock 1995 - 2001 Explorers 2
F 1996 A/C Clutch Engaging Issue Stock 1995 - 2001 Explorers 9
C 97 Explorer XLT 2WD 5.0/Clutch Plates Stock 1995 - 2001 Explorers 3
1 What is this clutch issue? Stock 1995 - 2001 Explorers 1
N Changing a Clutch in Explorer Stock 1995 - 2001 Explorers 5
3 AC clutch only engages with jumped low pressure switch Stock 1995 - 2001 Explorers 13
BobWiersema Ford TracLoc Clutch Set, Short Ears? Stock 1995 - 2001 Explorers 8
Mbrooks420 Fan clutch wobbles on water pump, 5.0 Stock 1995 - 2001 Explorers 59
Mitchs07explorer Fan clutch removal help Stock 1995 - 2001 Explorers 5
L Intermittent AC, no clutch engagement, odd woosh sound at idle...overcharged? Stock 1995 - 2001 Explorers 11
T 5r55e rebuild help,forward clutch drum Stock 1995 - 2001 Explorers 7
J AC Clutch won't disengage Stock 1995 - 2001 Explorers 5
D Install rocker switch for AC compressor clutch Stock 1995 - 2001 Explorers 2
J Stuck fan clutch nut Stock 1995 - 2001 Explorers 116
9 New Clutch Stock 1995 - 2001 Explorers 2
F Fan Clutch Nut Size? Stock 1995 - 2001 Explorers 0
S 2000 Explorer Sport - No Clutch Pressure Stock 1995 - 2001 Explorers 2
J Clutch replaced! Stock 1995 - 2001 Explorers 0
T fan clutch tool Stock 1995 - 2001 Explorers 13
Z Clutch kit, slave suggestions? Stock 1995 - 2001 Explorers 4
Z No clutch pressure, won't disengage Stock 1995 - 2001 Explorers 0
MINERALGSVT A/C Compressor Clutch Hub - mounting bolt? Stock 1995 - 2001 Explorers 5
R sticking clutch Stock 1995 - 2001 Explorers 6
fast_dave I need threads/tips on Clutch Replacement on a 4X4 SPORT Stock 1995 - 2001 Explorers 9
J 2001 torque converter clutch not disengaging Stock 1995 - 2001 Explorers 16
N Clutch Pedal to Floor Stock 1995 - 2001 Explorers 5
rasouth Coast clutch solenoid Stock 1995 - 2001 Explorers 0
Y Code 628 excessive converter clutch slippage HELP me Stock 1995 - 2001 Explorers 4
D Transfer Case Clutch Assembly Question Stock 1995 - 2001 Explorers 0
B Quick Help: Bad clutch = truck won't fire up!? Stock 1995 - 2001 Explorers 6
S 97 sport clutch change Stock 1995 - 2001 Explorers 10
P No power to A/C clutch ? Stock 1995 - 2001 Explorers 3
M Clutch won't disengage Stock 1995 - 2001 Explorers 7
B A/C clutch Stock 1995 - 2001 Explorers 4
D Crank but No Start Problem - Connected to Air Conditioning Clutch? Stock 1995 - 2001 Explorers 0
R A/C Clutch vs Compressor Stock 1995 - 2001 Explorers 3
2 A/c clutch replacement. Stock 1995 - 2001 Explorers 6
B Installing the FS10 Clutch Assembly for AC? Stock 1995 - 2001 Explorers 33
J compressor clutch cycles every few moments Stock 1995 - 2001 Explorers 12
V Clutch master cylinder woes Stock 1995 - 2001 Explorers 1
T Diagnose a bad fan clutch? Stock 1995 - 2001 Explorers 14
K 98 explorer 5.0 fan clutch Stock 1995 - 2001 Explorers 9
L Compressor/clutch noise - cause for concern? Stock 1995 - 2001 Explorers 6
J What caused forward clutch to fry? Stock 1995 - 2001 Explorers 2
S A/C clutch engages once then nothing Stock 1995 - 2001 Explorers 1
S Fan Clutch Stock 1995 - 2001 Explorers 3
P clutch problem / gearbox problem Stock 1995 - 2001 Explorers 3
J Fan clutch spin which way? Stock 1995 - 2001 Explorers 2
G clutch master cylinder 98 explorer Stock 1995 - 2001 Explorers 0
W No power at T case clutch Stock 1995 - 2001 Explorers 0
Similar threads
