A/C Clutch stuttering on/off.
AZExploder
Phoenix, AZ
2010 Mountaineer Premier
2010 Mercury Mountaineer AWD 4.6l 3V - 260,000
Issue has been going on for about 3 summers now.
AC is fine all fall, winter (defrost), and spring. Temps climb over 105 - 120 deg the symptoms come back.
Recent Replacements chasing issue with the advice of ASE tech and all Ford/Motorcraft parts to no avail:
  1. New AC - all of it
  2. New COPS/Plugs
  3. New Injectors
  4. New Intake
  5. New Wiring harness (another thread has that disaster)
Symptoms:
  1. Engine runs fine with AC turned off - all the time.
  2. Engine runs fine with AC turned on until warmed up, then clutch stutters and engine bogs and hesitates, coughs and bucks.
    1. Stutter lasts 10-20 seconds, then clutch disengages
    2. Stays disengaged for 10-20 seconds
    3. Engages for 10-20, then stutter returns and cycle repeats.
  3. Turn off AC, engine runs fine again all day as I slowly melt away.
stutter = on/off 2-3 times a second.
Today fiddled with the low side AC with a cr@p gauge. After warming up and the clutch disengaged, I released some freon for a second. Once the clutch engaged and then disengaged after stutter, released more. Repeated several times. Low side pressure slowly minimized in the green and maximized just into the red. It seemed to reduce the stuttering and bucking. It has "cooled " down to 100 so not a great time to test. Will tomorrow.
Any suggestions?
Gmctyphoon
PA
2002 Explorer 4.6
I was interested when this was on the engine harness thread. So I’ll still try to help here.
You gave a lot of great info, and a weird problem. When you say all of the ac, do you mean ALL? Compressor, condenser, lines, expansion valve, evaporator, orifice tube? Who filled the ac and how?
Have you cleaned the throttle body or MAF sensor lately or ever. 260k miles is a lot, and all sorts of stuff can be messing those two up.
For this issue I’d me more interested in the throttle body.
AZExploder
Phoenix, AZ
Last night I pulled the top side of the wire harness - COPS, injectors, sensors - and dabbed a bunch of dielectric goo on each plug and re assembled. I also charged up the battery. I took for a spin up and down the new freeway at 65 for around 30 minutes. After worm up - about 2 miles/4 min, she ran fine without AC, ran like poo with AC on. I only ran the AC for 2 min or so to confirm the stutter was ongoing at various speeds.
I got off the freeway and within 30 seconds i got the wrench and limp mode engaged. Trans would not shift up from 3rd.
Codes at the time: P0054/ P0060/ P0073/ P1000
AZExploder
Phoenix, AZ
Tonight I pulled the airbox and found a bundle of wires under the box that where visibly marked from the box sitting on them. I pulled the wires apart and they were stuck - as in the jackets were welded together. None seemed to be broken or warn though. After separating them, i wrapped them in tape and then taped them into the proper channel they had moved out of over the years.
AZExploder
Phoenix, AZ
*** All of it was done my the guy who has been working on all my cars for 8 years, including multiple AC jobs in F250, Expeditions, evac and charges in my hondas and mercurys. I believe it was the entire kit from FoMoCo - hoses, and hard parts. Seems the AC compressor is a difficult bugger to get out.
*** Cleaned the MAF regularly when I oil the filter. Cleaned the TB when I replaced the Intake Manifold.
AZExploder
Phoenix, AZ
Also tonight - I pulled the trans plug and verified the pins were intact and they checked out fine. Looked for burnt of frayed wires, vacuum tubes, anything out of the ordinary.
Test drive for 45 min ran fine. AC continues to blow - in a bad way.
FORScan Codes below:
===APIM DTC U3003:16-28===
Code: U3003 - Battery Voltage
Additional Fault Symptom:
- Circuit Voltage Below Threshold
Status:
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Accessory Protocol Interface Module
===END APIM===
===TCM DTC U0073-FF===
Code: U0073 - CAN communication bus fault
Module: Transmission Control Module
===END TCM===
===PCM DTC P0053-FF===
Code: P0053 - HO2S11 heater resistance out of limits.
Module: Powertrain Control Module
===END PCM===
===PCM DTC P0054-FF===
Code: P0054 - HO2S12 heater resistance out of limits.
===END PCM===
===PCM DTC P0059-FF===
Code: P0059 - HO2S Heater Resistance (Bank 2, Sensor 1)
===END PCM===
===PCM DTC P0060-FF===
Code: P0060 - HO2S Heater Resistance (Bank 2, Sensor 2)
===END PCM===
===PCM DTC P1000-FF===
Code: P1000 - On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
===END PCM===
===OBDII DTC P0053-P===
Status:
- Pending - malfunction is expected to be confirmed
Module: On Board Diagnostic II
===END OBDII===
===OBDII DTC P0054-P===
Status:
===END OBDII===
===OCS DTC ===
Successful DTC reading, no error codes found
Module: Occupant Classification System Module
===END OCS===
===4X4M DTC B1318-2F===
Code: B1318 - The battery voltage level is too low.
Status:
Module: 4X4 Control Module
Diagnostic Trouble Code details
Battery Voltage Too Low
--- Possible Causes --------
- Battery Voltage below 9.6volts
-Suspect Battery state of charge Charging system
===END 4X4M===
===4X4M DTC U1900-2F===
Code: U1900 - CAN Communication Bus Fault - Receive Error
Status:
Note:
DTCs that start with 'U' are faults which occur during module-to-module communication.
Modules should never be replaced based only on a 'U' code. These codes do not always indicate a problem, and can be caused by normal diagnostic functions, carried out on the vehicle.
===END 4X4M===
===ABS DTC ===
Module: Antilock braking system
===END ABS===
===RCM DTC ===
Module: Restraint Control Module
===END RCM===
===IC DTC ===
Module: Instrument Cluster
===END IC===
FORScan DTC list
Mon 8/3/2020 8:19 PM
AZExploder
Phoenix, AZ
Has new alternator - battery is just over 3 years old.
AZExploder
Phoenix, AZ
so - tonight - drove into the hills above Phx and just a tad of a trail drive - cool down and see some stars
I reset the computer and installed a new battery. 130 miles and 4 hours was not enough to clear the P1000, but the rest of the FORScan are below:
P0011 , P0021 ,P0054 ,P0060, P0341, P0346, P2195, P2197, P0011, P0021, P0054,
===PCM DTC P0011-FF===
Code: P0011 - Intake Camshaft Position Timing - Over-Advanced (Bank 1)
This DTC may be caused by :
The solenoid may be mechanically stuck
Engine mechanical fault.
===END PCM===
===PCM DTC P0021-FF===
Code: P0021 - Ignition Signal(IGNS).
--Possible Causes--
- Damaged resistor/condenser.
- Damaged power transistor.
- Open in coil VPWR circuit.
- Open in PCM output signal circuit.
- Short to GND in PCM output signal circuit.
- Open in coil GND circuit.
- Open in PCM input signal circuit.
- Damaged coil.
- Damaged PCM.
--Possible Causes--
- Damaged coil.
- Damaged PCM.
===END PCM===
===END PCM===
===END PCM===
===PCM DTC P0341-FF===
Code: P0341 - Camshaft Position Sensor A Circuit Range/Performance (Bank 1 or single sensor)
Follow the routines in the service manual to resolve the DTC listed.
===END PCM===
===PCM DTC P0346-FF===
Code: P0346 - CID A Circuit Range/Performance (Bank 2)
===END PCM===
===PCM DTC P2195-FF===
Code: P2195 - HO2S11 not switching correctly. Sensor indicates lean.
Air leaks at the exhaust manifold
Low fuel pressure.
Manifold vacuum leak.
HO2SHTR11 Heater Circuit Malfunction
===END PCM===
===PCM DTC P2197-FF===
Code: P2197 - Lack of HO2S21 Switch Sensor indicates Lean
Suspect HO2S21.
Ignition misfire.
Low fuel pressure.
Disconnected or Damaged vacuum hose.
Restricted or Damaged fuel injector.
Suspect PCM.
===END PCM===
===OBDII DTC P0011-P===
Status:
===END OBDII===
===OBDII DTC P0021-P===
--Possible Causes--
- Damaged coil.
- Damaged PCM.
Status:
--Possible Causes--
- Damaged coil.
- Damaged PCM.
===END OBDII===
===OBDII DTC P0054-C===
Status:
- Confirmed - malfunction is confirmed
===END OBDII===
Check of all systems is not complete since last memory clear.
--Possible Causes--
- The vehicle is new from the factory and has not yet been through a complete OBD Drive Cycle.
- The battery or PCM has been disconnected.
- An OBD monitor failure had occurred prior to completion of an OBD Drive Cycle.
- The PCM DTCs have been cleared as part of a service process.
Note: The only way P1000 can be cleared (removed) from memory is when all of the OBD monitors have been successfully completed during normal vehicle operation.
P1000 cannot be cleared from the PCM when: 1. The thermostat is stuck open and a DTC is not generated. 2. There is an open VSS circuit and a DTC is not generated. 3. If the vehicle has a Power Take Off (PTO), the circuit is shorted to VPWR or B+, or the PTO is ON during Self-test.
The purpose of the Diagnostic Trouble Code DTC P1000 is to indicate that not all of the On Board Diagnostics OBD monitors have yet been successfully completed. You may also refer to the OBD Drive Cycle defined under the Powertrain Control/Emission Diagnosis Manual-Diagnostic Methods or the Owner's Manual.
Remember: It is not necessary to remove P1000 from the Powertrain Control Module PCM by driving the vehicle.
===END PCM===
===OCS DTC ===
===END OCS===
===APIM DTC ===
===END APIM===
===TCM DTC ===
===END TCM===
===4X4M DTC ===
===END 4X4M===
===ABS DTC ===
===END ABS===
===RCM DTC ===
===END RCM===
===IC DTC ===
===END IC===
AZExploder
Phoenix, AZ
My Ebay PCM fell though after waiting 2 weeks - so I got another one ordered from Flagship One online.
now i wait.. again.
AZExploder
Phoenix, AZ
Had to cancel the Flagship One computer - 3 weeks they had my $500... called 8 times and emailed same.. never any contact. Had Paypal get my money back.
Finally got another PCM - had Ford program and update, and drove fine for a day and 50 miles..
.... aaaand, just limped home over city streets for 60 miles, not able to shift out of 2nd..
and new codes, same as the last..
Car Scanner ELM OBD2
DTC report
Selected brand: Mercury
VIN: 4M2EN4J84AUJ01534
============1==============
U0101
Raw code: C101
ECU: Engine control unit
Status: Pending
OBDII: Data bus, transmission control module (TCM) - no communication
============2==============
U0100
Raw code: C100
ECU: Transmission control unit
Status: Pending
OBDII: Data bus, engine control module (ECM) A - no communication
============3==============
U0073
Raw code: C073
Status: Pending
OBDII: Control module - data bus Off
============4==============
U1900
Raw code: D900
ECU: ABS/ESP
Status: Validated and stored in non volatile memory, Validated fault present at time of request, Validated fault has been present during this drive cycle
AZExploder
Phoenix, AZ
I saw this post so I invested an hour or so cleaning and jumping grounds using some leftover amp power wire..
aaannd.. no.. Quest continues..
