If you select vent only or floor only, the a/c compressor should not cycle on. Any other setting will run the compressor. I also don't know why Ford did it this way, unless they were encouraging the a/c to be used more often (and maybe prevent the seals from drying out).
I have the fan set as low as possible, temp on hot and the mmode switch if you will set to the split setting floor and vents like above the radio and in the corners and am I right in saying the a/c compressor should not cycle at all
No there isn't an issue. That is the way it is designed. Having it set to heat has nothing at all to do with whether the AC compressor runs. If you have the mode switch set to dash vent and floor position, the AC compressor will run by design. You may not want it to work that way, but that is the way it is built. If you put the mode switch on dash vent ONLY or if you put the switch on floor vent ONLY, the AC will be off. Any other setting and the AC will run.
As indicated, the AC is enabled when the top (defroster) vent is enabled to remove moisture from the air and help defog the windows. However, that does not explain the vent/floor combined mode engaging the AC, which is the mode that always bothered me.
I appreciate everyones input but it seems there is some contradiction, The compressor is cycling on when I have heat blowing on the split setting of floor and the vents above the radio not defroster vents. One of you is saying a/c is on for every setting but vent and floor. If that is the case then there is a issue.I am apppreciative of your help, just trying to figure it out
The compressor will run on all settings except VENT ONLY and FLOOR ONLY. VENT + FLOOR split setting will run the compressor.
De-humidification.
Any modern car with Automatic AC will do that, because (live) people exhale water vapors (besides CO2) that will accumulate in the cabin and fog up the windows.
The AC will not work also if outside temperature is low enough.
I understand that, but sometimes I don't want the A/C to run (if its not humid, for example, and I don't need cooling). Waste of fuel. Also, there's no way to use RECIRC unless I want max a/c. Would be much better to have separate A/C and RECIRC buttons like virtually all new cars and most older Japanese cars.
