a/c issue - drivers side not cooling | Ford Explorer Forums - Serious Explorations
dontgetbit
Raleigh, NC
2003 E.B.
I just got my '03 Eddie Bauer back from the dealer after having the drivers side head replaced under warranty and now I have another issue. When I turn the a/c on with the temp. set at 60, the drivers side blows warm air and the passenger side blows cold air. I have the dual climate control and have tried everthing to get both sides the same temp. but it does not work. The drivers side air does eventually get cold but it takes 15 minutes or so to get to a comfortable temp.
Has anyone else had this issue? What could cause this?
I contacted the dealer and have scheduled to get it check out, but if its like everything else that I show them I will get the usual, can not reproduce......blah blah blah.
mine is doing this exact same thing, except the driver's side is cold and the passenger side is hot... only does it every now and then, not always.
(2002 Mountaineer)
Mine is doing this now too. Did you ever find out what was wrong? (2002 Mountaineer)
Mine is doing this as well anyone find an answer?
