A/C leak help | Ford Explorer Forums - Serious Explorations
A/C leak help
IvDogg
Ewa Beach, HI
1994 Limited
-My A/C has a very slow HFC-134 leak, it's leaking from the valve that you connect to when you re-charge the A/C.
Can anyone give me some tips on how easy or hard that will be to replace?
Like can just that tips be replace or fixed?
Thank you.
It's basically a Schrader valve like your tire valve stems. It may just need tightening or the core replaced.
I had the same problem with on a 94. I found the correct replacement screw on valve at Pep Boys. I think it was $7 part, but was worth it to keep the freon in the system.
The cap that is supposed to be on that port has an o ring and will also stop the leak.
Thanks for the quick replies guys. I'll wait till my system runs out of hfc134 then try it out.
