A/C Leaking r134a,,,, but I can't find the leak,, even with UV dye.
Juckerz
Apopka, FL
2004 Explorer XLT
2004 Explorer XLT 2wd
My refrigerant is going somewhere,,, a full charge lasts about a month,,,, compressor works fine when the system is charged. I recharged the system and put dye in today,,, blowing ice cold during a 30 minute drive,,, but afterwards,,,, could not find a trace of a leak in the engine bay,,, top or underside,, nothing leaking under the car.
I'm a fumbling idiot,,,please don't shout at me,, I'm just guessing. Does this mean the problem is behind the firewall? Evap or condenser?
Is there an easy way to check either without removing the dash? (There is no trace of dye inside the car that I can see, vents etc).
Thanks guys for any help,,, I'm no expert,,, just a timing-belt 'level' home mechanic,, but if it's something I can take on,, I will.
Joe in NY
Binghamton, NY
2002 Eddie Bauer V8 4X4
get a flexible camera, remove the blower, and stick the camera into the evaporator area and look for dark colored dirt patches where oil is leaking out and debris is sticking
Juckerz
Apopka, FL
2004 Explorer XLT
The blower? lol,, where is that exactly? and how do I remove it. :)
shucker1
Metairie, Louisiana
98 XLT 5.0
If you have Freon Gas Sniffer this method has worked for me in the past.
Charge system. Let vehicle sit for several hours.
Put Freon sniffer in center console vent and turn the key on, with low blower setting, but do not start the engine.
If the evaporator is leaking you should get a brief indication on the Freon Sniffer as the blower sucks up the Freon that has accumulated in the case.
boominXplorer
Elite Ranger
Virginia Beach, Va
00 4x4 Mounty
Check the dash drain for oil/dye
Juckerz
Apopka, FL
2004 Explorer XLT
Do you have caps on the service ports?
Yes Sir,,, caps in place,, no leaks on either side,, or along any of the lines,,, dryer & compressor totally clean too.
Juckerz
Apopka, FL
2004 Explorer XLT
Has anyone had any luck with these sealant products? I figure if it takes a month to lose charge,,, it must be a fairly minor leak.
Juckerz
Apopka, FL
2004 Explorer XLT
Thanks for all the advice btw,,, I appreciate it,,,, about to go borrow a sniffer from a friend.
