ftexplorer
- September 20, 2005
- Caldwell, NJ
- 00 XLT
I have a 2000 V6 SOHC 4WD Explorer. The a/c has not been running cool on the highest fan setting but not cold. I thought the a/c needed a recharge and bought the EZ Chill can with the pressure gauge on it. The car was hot and outside temp was 90 degrees. The air was on max, and I hooked up the can to take a look at what the gauge said. It was in the yellow zone with a reading of about 55 PSI. So I didn't add any coolant. I'm not sure what to do at this point as I don't have any a/c experience. Some post I read said those gauges suck, but I would imagine it is decently accurate.
What problem could be causing the a/c to run not as cold?
