barking004
- May 17, 2012
- 2004 explorer EB
Hello, hope you can help. I'm concerned about the vent temperature and possibly the compressor so here are my observations:
2004 ford explorer 4.6 L V8
First test
A/C off
Low pressure port reads 70 psi
High pressure port reads 70 psi
Second test
A/C full on including rear a/c, engine at idle
Low pressure steady at 40 psi ( does not cycle)
Hi pressure 175 psi but has some vibration ( assuming from compressor)
vent temperature = 60F; should be much lower?
Low pressure steel tube is cold but not frigid, hi pressure tube is hot with some vibration.
Then third test, same as above but engine at 1200 rpm
Low pressure cycles between 22 and 40 psi.
Hi pressure 175 psi.
no change in vent temperature.
todays outside temperature is 80F.
So what is wrong?
thanks for your help.
First test
A/C off
Second test
So what is wrong?
