Hello,
I have a 98 explorer with A/C issues. compressor didn't run. I put a recharge hose on it on the low side and gauge read about 5 pounds. I jumpered the cut off switch causing the compressor to cycle and put one 15 oz can of the 134 into the system. It came up to about 15 pounds and air got semi-cool. According to the kit I should have between 25 and 45 pounds of pressure in the system. so I was planning on putting another can into it. After the wife brings it home today, I put the gauge on without the motor running and pressure is spiked up at 100psi. I start the truck up, and turn on the A/C. when the compressor is cycling, the pressure starts dropping towards 15, as soon as the compressor cuts out, it spikes back up to 100 again. Is this normal? there's a stink coming out of the engine compartment now and I'm guessing it's my expensive freon leaking back out (obviously the stop leak additive in this kit wasn't successful)
