A/C problems on a 1997 Explorer with electric climate control. | Ford Explorer - Ford Ranger Forums - Serious Explorations
sb11591
Atlanta
1997 E.B. 5.0 Awd
We bought this Explorer new and it has been very well maintained. No accidents, no major problems. For the last three years the AC hasnt worked correctly, barely cooling a full refrigerant charge. The heat would only work when it wants to, and only if the temp is on 65, nothing else, it works for a few days then stops for a few weeks. Ive put much thought into this and the way I see it is that there can not be a vacuum leak b/c the heat does work sometimes so the vacuum lines must be ok. Ive been told these control units are notorious for failure. im finally getting around to fixing it, and i am leaning toward a bad blend air door actuator, and the control unit. So I am wondering if anyone has any ideas or know of common problems in this year model and w the electric climate controls.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
