A/C problems.
HappyHr247
San Diego, CA
'98 XLT
I have a 1998 ford explorer with over 314,000 on it. Recently I've been having issues with my A/C not coming on. The charge is good but for some reason when it's hot out the compressor shuts off and then just blows humid air. Thought it was wiring but it's not as far as I can tell. Any suggestions anyone?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
ErnieX
Melrose, FL
96 XLT
If you tap on the clutch faceplate will it engage? Could be too large an air gap between faceplate and coil due to wear (300K+). Gap should be about thickness of a business card.
Just a shot in the dark but I had same symptoms and this was the problem.
Hope this helps,
EE
HappyHr247
San Diego, CA
'98 XLT
Tap tap
ErnieX, Tapping on the clutch faceplate works. How do I fix that problem? My gap is about 3/16".
ErnieX
Melrose, FL
96 XLT
If you removed the bolt on the front of the clutch the faceplate will come off. Ease it off and mine had a factory spacer washer inside the little hub. I removed the spacer and reinstalled the face plate. Check the gap - should be about the thickness of a business card. You could use a smaller spacer if the gap gets too tight.
Hope this helps.
EE
HappyHr247
San Diego, CA
'98 XLT
Thank you, ErnieX. I'll try that and let you know.
HappyHr247
San Diego, CA
'98 XLT
It worked
EnieX,
Took the spacer out and so far so good. Thanx again :)
B AC problems, no gauge movement A/C & Heater systems - HVAC 4
I 1993 Explorer 2 Door Sport 2WD ALL new A/C problems A/C & Heater systems - HVAC 2
imp ENGINE COOLING PROBLEMS, THERMOSTATS(?) A/C & Heater systems - HVAC 0
C 5th Gen Possible blend door problems A/C & Heater systems - HVAC 1
X AC Problems A/C & Heater systems - HVAC 4
S 98 Explorer A/C Clutch problems A/C & Heater systems - HVAC 1
D heating problems A/C & Heater systems - HVAC 1
N How many problems do I have? A/C & Heater systems - HVAC 6
J A/C Problems A/C & Heater systems - HVAC 0
L Couple A/C and heater problems A/C & Heater systems - HVAC 2
B Overheating problems....again. A/C & Heater systems - HVAC 0
S Air conditioner problems. A/C & Heater systems - HVAC 1
R 2002 Explorer Sport. A/C problems. A/C & Heater systems - HVAC 1
B A/C blower problems. A/C & Heater systems - HVAC 1
D A/C blowing problems. A/C & Heater systems - HVAC 1
T 2002 Eddie Bauer. A/C problems. A/C & Heater systems - HVAC 2
J A/C problems. A/C & Heater systems - HVAC 1
S A/C problems on a 1997 Explorer with electric climate control. A/C & Heater systems - HVAC 2
M A/C problems. A/C & Heater systems - HVAC 3
R Heater problems on a 98 Explorer. A/C & Heater systems - HVAC 6
M Problems with 2004 XLT Air & Heat... A/C & Heater systems - HVAC 0
D A/C compressor problems. A/C & Heater systems - HVAC 2
M 1996 XLT with climate control problems. A/C & Heater systems - HVAC 5
F A/C problems. A/C & Heater systems - HVAC 1
G A/C problems. Help please. A/C & Heater systems - HVAC 4
Andy96XLT AC compressor is giving me problems A/C & Heater systems - HVAC 2
G AC accumulator for '02 Mountaineer..problems! A/C & Heater systems - HVAC 2
M 1998 Limited Heater Problems A/C & Heater systems - HVAC 0
R 2002 Ford Explorer air conditioner problems. A/C & Heater systems - HVAC 2
A '00 XLT A/C Problems A/C & Heater systems - HVAC 0
C 1997 Explorer heater problems. A/C & Heater systems - HVAC 12
K Air conditioning problems. A/C & Heater systems - HVAC 1
G Spring Lock Coupling Problems A/C & Heater systems - HVAC 2
M A/C problems A/C & Heater systems - HVAC 3
O Trying to diagnose AC problems A/C & Heater systems - HVAC 2
R Problems adjusting between hot and cold A/C & Heater systems - HVAC 2
8 Climate control problems A/C & Heater systems - HVAC 4
E a/c problems A/C & Heater systems - HVAC 8
S Frustrating '97 Ford Exploder Sport AC problems... A/C & Heater systems - HVAC 3
D '96 Eddie Bauer V8 Explorer A/C Problems A/C & Heater systems - HVAC 1
G hot cold control problems A/C & Heater systems - HVAC 1
D 00 Explorer climate control problems A/C & Heater systems - HVAC 1
J heater problems A/C & Heater systems - HVAC 3
T 04 Explorer XLT - heater problems A/C & Heater systems - HVAC 2
BKennedy AC problems A/C & Heater systems - HVAC 15
firewolfm AC quick connect problems A/C & Heater systems - HVAC 5
T A/C Problems A/C & Heater systems - HVAC 4
L problems withe heater A/C & Heater systems - HVAC 0
Similar threads
