SyberTiger
- May 18, 2007
- Orlando
- 2002 Limited 4x4 4.6L
I have a 2002 4.6L, no rear a/c system.
I'm looking at the Chilton manual which calls for Motocraft YN-12-C for the PAG oil. Doing a quick search I can't find YN-12-C, only YN-12-D. Is D the replacement for C? Is there a generic PAG oil that can be used in place of the Motorcraft. Looking at THIS CHART is would appear that PAG46 would be used.
Looks like my A/C Manifold Hose Assembly is leaking as noted by the presence of PAG oil right at one of the hose crimps where the high pressure output of the condenser is located. In the picture it's the upper crimp on the right side.
Since my compressor hasn't locked up I was thinking about changing out just the manifold hose assembly and nothing else. Since the compressor hasn't locked or blown-up I'm thinking that a flush of the system is not necessary. How much PAG should I put in the system if I'm not flushing out the old stuff but yet know that some of the PAG has leaked out. The Chilton manual does not show the amount of PAG oil to add. Maybe add 2oz of PAG46 and call it good?
How much refrigerant is needed? The Chilton manual does not show the A/C system capacity.
