I have the same issue right now--
the function is switched by vacuum only--there are a few things to check
looking up in the front passenger wheelwell-there is a black globe, about the size of a softball. Thie is the vacuum reservoir-
it is tough to find, but it is there. you will need to look between the fender, and fender liner--
look at the vacuum lines going to and from it for leaks or breaks.
Also, trace the lines back to the firewall, where they make a bulkhead type connection to go thru the firewall
next--you could have a bad vacuum switch, on the control panel--
This is not a blend door issue--so don't get confused--
The blend door controls heat to cold function only--
