- February 18, 2009
- Winnipeg, Manitoba
- 00 Limited V8
So, I filled up with gas, and very quickly had stumbling, trans codes, and all 4 o2 sensors firing codes.
Immediately, I felt it must be bad gas. I syphoned it out, and refilled. Within 2 miles the truck ran great. I was sure it was the gas. 2 days later its coming back, intermittently.
I did a code check and I have these codes, although the check engine light hasn't come on yet.
P1747 Pressure control solenoid A short circuit (see P092)
P0750 Shift solenoid A
P0755 Shift solenoid B
P0743 Torque converter clutch electrical circuit
P1451 Evaporative Emission system vent control circuit
I found this thread that seems very similar to what I am seeing:
http://www.explorerforum.com/forums/showthread.php?t=392916&highlight=p0750
With me, the issue is intermittent, suggesting a wiring issue. I'm not convinced bad gas caused this anymore. What's with the P1451?
Its interesting that before draining and refilling the gas tank I had O2 sensor short codes on all 4 o2 sensors, but those codes didn't show up this time (yet, anyway).
I'm starting to think I have a wiring issue. Intermittent..
