Alwayssideways
- March 10, 2012
- Newington, CT
- 2003 Sport Trac
Hi All,
I dont post much. I normally just troll for info when needed. Now After going through a few threads I need some help with a current problem I am having with my 2003 ST.
I had changed the front hub bearings a few month ago. At the same time they had just paved my road. After getting the bearings done driving down the road I heard a louder than normal road noise. I contributed it to the grippy AT 32" I have on the truck due to it really only got "really noticeable" on my freshly paved road. Well the past few times taking the truck out I had smelled what I thought was something like hot plastic. I didn't think much of it since the operating temp of the truck was fine and the truck was running well.
Fast forward to today. I noticed a small (about golf ball sized ) puddle under the front axle of the truck . Smelled it, and it was gear oil. I looked under the truck and saw the front diff was wet. So I figured it was the diff cover, but researching more and more it sounds like my pinion bearings are shot . My evidence which match symptoms from other posters with bad pinion bearings. Leaking diff, specific sound (confirmed on you tube to match the "road noise" I have now, the fact the diff is heating up and causing a hot plastic smell.
I haven't gotten to get under the truck to see if there is play in the bearings yet. It is night time and I will look at it in the day light tomorrow. I am just preparing myself for a few scenarios if needed.
1. how hard is it to remove the front diff?
2. Roughly what would a trans shop charge to replace the bearings (if I take the diff off and leave it with them)?
3. Can the truck be temporary be made 2w drive while I save up for or wait for the diff to get rebuilt? (i.e remove diff, axles and drive shaft)
Any help would be appreciated.
Thanks
Thanks
