DaveEX93
- September 9, 2002
- Ontario
- 93EX
Ok ive lifted a few Rangers and broncoiis already
but am about to attempt to lift up and explorer
what i need to know is
the drop brackets ( axle and Radious arms)
are the same off an 1983-1997 Ranger/ BroncoII
kit correct?
so basically and lift kit off and 1996 Ranger ( 6" superlift)
will work on the front end of say and 93 explorer
because the coils and drop brackets should be the same
are they not?
i know the rear of the explorer is a tad different
seeing its spring under the axle OK my welding
is not that great so i'm not going to even attempt
the spring over till later on ( maybe next fall)
whats my best way to gain 5-6" out back of my explorer to level it out with the front?
will a set of shackles and add leafs do the trick?
and were and what kind do i need to get?
OK last but not least question is...........
with this lift installed and all and done will my driveshafts still be ok?
I know when i did my 91 Ranger with the 4.0L
with the 6" suspension lift and 3" body lift and
ran 35's for 3 years befoer selling i had no problems
with driveshafts OH and this is adn 4dr explorer
thanks
daveM
kit correct?
are they not?
thanks
daveM
