A few upgrades..
mattd08
Bristol, Va
02 XLT
A few upgrades i have added over the past few weeks:
Painted Pillars
Also, added clear corner lights
Added tail light guards
Threw a nice wax job on it and sprayed the whole undercarriage with rust-oleum spray.
I also have a cold air intake that i am waiting on from UPS: http://www.secretweaponperformance.com/product/Dragon-Intakes/Default.aspx
I have been reading into installing two distance or off road lights behind the grill, but im having trouble understanding how everyone is getting those lights to stay in place behind the grill. I will be getting some lights here shortly so any help or insight will help out alot, Thanks!
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
therover1991
Queens, New York
02 XLT
The car looks great good job.
For the lights behind the grille I bought two metal brackets to secure the lights to then drilled holes in the brackets and screwed them into the car. I havent had any issues with them and they help a lot on dark roads.
jad2411
El Paso, TX
2007 Brown eb
Nip slip....
jad2411
El Paso, TX
2007 Brown eb
lol J/K :p:
Truck looks great, mine hasn't been washed in like 6 months :S
fedyfedz
Suffolk County, NY
2002 limited v8
sweet nice ride. for the lights if you want to go the cheap lazy way that I did i used a 2x4 cut in half one for each light put blocks behind grill, seemed to be a perfect ledge for it, then drilled light into wood. only thing is u have to make sure its back far enough because my billet grill pushes up against them causing them to be pointed slightly up. I dont mind it cause i have a roof rack with lights and full hids so having these lights point slightly up in to the tree line makes it perfect for my use.
armysoldier30263
Shaw AFB, SC
05 BLACK 4.0 XLT
hey matt what did you use to paint the pillars?
and is the intake for the 4.0 the same on the 04 as the 05 ... that intake looks BA would love to get one and btw the x looks great ... what are your future plans for it?
ajthefishermen
Conneticut
02 XLT
Great looking truck! I was wondering if you have an aftermarket exhaust or is just a tip? Also what brand tires are those!
mattd08
Bristol, Va
02 XLT
Thanks jad and fedy! Thanks for the insight on mounting the lights.
Fedy-do you have all of your aftermarket lights wired into the same swith or what?
Armysoldier-I used a simple gloss black paint from autozone (3 coats of that) then i hit it with an automotive clear (2 coats). I love how it turned out! As for the intake, i dont know anyone who has these intakes on their Ex so i will have to do some reading and further looking into the intakes to see if they are the same. But after i get the intake installed, i want to get lights installed behind the grill and do a shock/strut replacement and POSSIBLY the 1.5" body lift.
ajthefisherman- I have a flowmaster 40 series with factory pipe into a 3" tip. It sounds pretty mean! And the tires are General Grabber AT2's (265-70-16)
mattd08
Bristol, Va
02 XLT
Therover1991- Do you have any pics of how you mounted the lights?
therover1991
Queens, New York
02 XLT
therover1991
Queens, New York
02 XLT
College Student
Indinapolis, IN
'03 EB
When you get the intake installed let us get a few pictures of it and how you like it, i might change which brand i look into
fedyfedz
Suffolk County, NY
2002 limited v8
actually i have a mini switch board everything is on its own individual switch this pic is oudated slightly.
the one not on the switchboard is for the lights behind my grill
the empty slot cut in the dash is for my thunder grill
and the two on the switch board are for the roof rack.
the other two will be for halos and something else that i havent thought of yet
therover1991
Queens, New York
02 XLT
Heres a couple pics to see how I mounted mine. Pardon the untidy wiring.
mattd08
Bristol, Va
02 XLT
Okay, thanks for the help. I have some fog lights wired up and im trying to see if i can run the fogs and lights behind the grill off of the same switch.
mattd08
Bristol, Va
02 XLT
Will do! Im supposed to get it at the beginning of next week so i will be installing it as soon as i get it. Which brand were you looking into?
therover1991
Queens, New York
02 XLT
I suggest the Hella 500s. Great light, durable etc. I put in a set of 55W HIDs in them to match my headlights and fogs and theyre great.
However I wouldnt recommend running the grille lights off the same switch as the fogs.
mattd08
Bristol, Va
02 XLT
I bet those look super good with the HIDS. Why would you not recommend running them off the same switch?
X A few upgrades...... Modified 2002 - 2005 Explorers 4
D A few cosmetic mods (2005) Modified 2002 - 2005 Explorers 8
A Lifting with spacers, few questions Modified 2002 - 2005 Explorers 10
F Installing Pioneer stereo in my '03 Mountaineer... Need a few tips. Modified 2002 - 2005 Explorers 4
C Few questions about 5.4 swap into 04 Mountaineer (4.6) Modified 2002 - 2005 Explorers 8
D new to site few questions. Modified 2002 - 2005 Explorers 17
N Newbie...few questions about swaps? Modified 2002 - 2005 Explorers 2
J New and have a few questions Modified 2002 - 2005 Explorers 7
F Why is Darth Vader living in my oem airbox?? and a few other problems Modified 2002 - 2005 Explorers 3
E A Few quick 3rd Gen lift quesions Modified 2002 - 2005 Explorers 20
B shock extention kit have a few questions Modified 2002 - 2005 Explorers 6
D Few more offroad pics in my ex. Modified 2002 - 2005 Explorers 6
K My Ex and a few mods Modified 2002 - 2005 Explorers 5
A Road trip! Few quick questions.. Modified 2002 - 2005 Explorers 4
shadowless127 Building custom CAI few questions Modified 2002 - 2005 Explorers 1
R HID's went out after only a few months! HELP!!! Modified 2002 - 2005 Explorers 10
U Few questions Modified 2002 - 2005 Explorers 1
G bullbar, few things repainted...lights or no lights?...and LOADS of pics Modified 2002 - 2005 Explorers 21
C a few pics with the new chrome and rubber Modified 2002 - 2005 Explorers 13
D Few pics w/ my 265s Modified 2002 - 2005 Explorers 2
P Few Questions Modified 2002 - 2005 Explorers 4
B A few pics of my X Modified 2002 - 2005 Explorers 23
T a few more Modified 2002 - 2005 Explorers 2
T Few Questions Modified 2002 - 2005 Explorers 9
P New to the Explorer Family.....Need advise on upgrades . Modified 2002 - 2005 Explorers 7
J 4.6 Upgrades??????? Modified 2002 - 2005 Explorers 7
J Intake replacement and upgrades!!! Modified 2002 - 2005 Explorers 0
M 4.6L performance upgrades Modified 2002 - 2005 Explorers 3
J Trans upgrades... Modified 2002 - 2005 Explorers 31
V Exhaust upgrades Modified 2002 - 2005 Explorers 10
orthoguy 4th Generation Upgrades Modified 2002 - 2005 Explorers 7
D Possible Upgrades on my 3rd Gen Modified 2002 - 2005 Explorers 0
W New 3rd Gen XLS owner... Upgrades? Modified 2002 - 2005 Explorers 4
M Newbie needs help with performance upgrades Modified 2002 - 2005 Explorers 7
Z Upgrades for 4.6 V8 XLT 2003. Modified 2002 - 2005 Explorers 207
Z Upgrades for 4.6 V8 XLT 2003. Modified 2002 - 2005 Explorers 0
MC05XLS Factory Upgrades Modified 2002 - 2005 Explorers 13
W Power Upgrades Modified 2002 - 2005 Explorers 3
Similar threads
