TexasRangerFX4
- May 25, 2012
- Houston, TX
- 2004 Ford Ranger FX4
I have a 2004 Ford Ranger 4x4 with a 5R55E and recently had to have the trans rebuilt. Within a couple of weeks of the rebuild, the trans started blowing out the OD servo cover. They transferred the parts to a new case and since then, I have had a 1-2 hang (takes too long to shift from first to second unless I give it very little gas) and a 2-3 flare (unless I give it very little gas). It is a long story as to why I am going to repair it myself, but I read the entire valve body rebuild diary thread (forty something pages) and have a question. I found some info on another forum, and wanted to know if anyone could verify that it is correct. I really couldn't find any specific info for a 2004 model, and the TSB only lists models up to 2002, so I wasn't sure if the parts even pertained to my truck until I noticed this thread where he mentions "2006 or later". I am planning on getting all of these parts, except for the Transgo kit, I will be using the Superior kit instead.
Thread from RPS
This parts list can be considered verified 100% accurate for the 4x4 version.
1. EPC – XL2Z-7G383-AA @ (get this if your over 60K or 2006 and older)
2. SOL BRACKET – XL2Z-7L491-AA (get this if your over 60K or 2006 or older)
3. FORD SEP PLATE – 1L5Z-7Z490-GA (get this if your tranny is 2006 or older)
4. FORD TSB KIT – 3L5Z-7M203-JA
5. FILTER - 56010G
6. GASKET - 56300EF
7. Transgo SK®44-55E
I mostly just need to know if 1 through 4 are compatible with my 2004.
Thanks for any help,
Chris
Thread from RPS
5. FILTER - 56010G
6. GASKET - 56300EF
Chris
