So last night I finished repairing the rusted out rocker panel on my Ex but still had a small 1/2" x 1/4" hole along the dog leg. I didn't want to tack weld it or use body filler so I decided to repair it the way they use to many years ago... soldering.
With some left over 60/40 lead solder and an old soldering gun I applied it to bare metal then smoothed it down with 60 grit sanding disc attached to my dremel. Personally, I think it came out way better than using body filler and maybe even stronger.
Question is, can I just primer over the bare metal or could I use some glazing putty to smooth out the imperfections, then lay down the primer? Here is a pic of the final project.
