- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
water proof it! The distributor and plug wires all get treated to repel water.
All electrical connectors get treated or replaced.
The vent tubes on the axles, tranny, t case, etc... all get moved up higher.
Basically the snorkel is only the beginning.....
There is a real good article on off0road.com about waterproofing.
The point is not to make a gasoline engine run under water, it's to make it so the ignition does not get wet enough to stall when your up to the headlights crossing a stream....
Of course unless it's a diesel if you get too deep it will stall....
