Andy94SC
- November 4, 2007
- Fenton, MI
- 1999 Mountaineer
I've pretty much decided I want to pick up an Explorer for a winter vehicle to replace the Thunderbird I've been using. We picked up a '99 Mountaineer last year for my wife, and it's been great, she doesn't want to give it up, so I need my own.
I want something cheap ~$2k or less. I know that means high miles, and less than prime condition. So I decided I should likely gort for a 5.0L powered version. I think that engine is more durable than the V6s.
So what i have found near me are two Eddie Bauers that I need to choose between.
#1 is a 1997 Very nice interior, slight body damage, needs a headlight and fender work, not much rust. Non working A/C and a bad front prop shaft that limits speed. Tires are kind of worn. I may find more problems once I get the prop shaft fixed and can drive it more. It seems to be loaded, Ride control, 6 disc changer brush gaurds etc. Price is around $2k, but they seem very flexible...
#2 is a 1996 slight body damage, a lot more rust in the rocker panels. I didn't get to test drive it yet because the dealer was closed when I went to see it. It looks very clean under the hood. The biggest issues I saw was that the interior looks a lot messier, not damaged, just like someone had spilled a lot of drinks or something in it. It had a mismathced set of tires, and no spare. Also all of the door latches are screwed up except for the passenger door. If you play around you can get the drivers door open. The rear doors don't open from the inside or outside, and the rear hatch is open and will not latch closed. It only has a cassette radio, but has a built in cell phone option? Not that I will ever use it... They are asking $1200.
I am pretty well mechanically inclined and can probably fix anything mechanically wrong. I am more concerned with cost. Both have about the same miles ~ 145k. Neither seems to be leaking any major fluids.
The local junkyard just got a very nice 2000 Limited in that I could get parts from , IF they would work on those earlier vehicles... Are there any major differences between a 1996 and a 1997? Any opinions on which I should persue assuming the 2nd one runs OK? Currently I am thinking the 1997 because it is a year newer, and has a nicer interior...
