A4LD 95 Explorer to Bronco II | Ford Explorer - Ford Ranger Forums - Serious Explorations
farmer
Seattle, WA
94 XLT
I would like to put the 95 Explorer A4LD transmission in my 88 Bronco II. I think that if I use the 88 Bronco torque converter and flex plate every thing will bolt up.
The reason for using the later Explorer transmision is to get the benifit from Ford upgrades. Thrust washers to bearings etc.
Will this swap work?
Thanks,
Farmer :)
Need a '94 or below. '95s are computer controlled, others are vacuum.
'95- 4R55E
'94- A4LD
