Masterd
- October 16, 2005
- Upland, CA
- 1993 Explorer Sport
Well since my A4LD is likely on its way out anyway, I'd like to add a few more symptoms...
When I let off the gas sometimes, and theres no engine braking, the tranny will make intermittent grinding noises as I slow down....
Also, now at idle sometimes, I'm hearing a hissing / rattle type of sound when its in gear...if I put it in neutral it goes away. Ill try and get some sound clips of it, if it comes back...I messed with the cat heat shield to see if it would go away...Ill know for sure tomorrow.
As always, aside from missing 4th gear, and having a stuck governor..everything else still seems to be working OK...
