natenkiki2004
Blue Bomb!
- November 3, 2013
- Location
- North Idaho
- 1991 & 1994 Explorers
A while back I noticed with my 1991 Ex that if I drove it around for a bit and went to park, it sometimes wouldn't roll back/forward until I shut off the engine. I was told it was likely excess pressure not being relieved until the engine, and thus transmission pump, was shut off.
I didn't think much about it until today while I was playing with a vacuum gauge. Engine & trans are warmed up, been driving for 10-15 minutes or so. Go back to park it and I'm looking at the vacuum gauge and it reads at 15 in.Hg where it was normally idling at 16-17.
I gave it a rev to see what would happen (while still in Park) and it was difficult to rev the engine (felt like it was under a load) and it would idle at about 800RPM. I put it in Neutral and the vacuum went back up to 16-17 with around 1000RPM idle and it was then easy to rev the engine again. Back to Park, vacuum was normal and easy to rev. I then put it in Drive with my foot on the brake and the vacuum went down to 15 in.Hg with 800RPM again, curiously, the same it was in Park just moments earlier. I moved the vehicle back and fourth and then put it in Park and it idled high and then slumped down to 800RPM and 15 in.Hg.
With the evidence, the revving, vacuum and RPM, it really feels like the transmission will be intermittently in both Park and Drive at the same time. I guess my first question would be, is this related to a persistent KOEO code 57? I've disconnected my battery several times for various things and not long ago ran the KOEO test right after reconnecting the battery and driving a short distance, the code 57 is always there:
Intermittent in Park/Neutral/ Switch or Neutral Pressure switch circuit – PNP or Transmissions
I thought this was just a switch to detect backup lights and prevent the vehicle from starting when in drive (both of which work as expected). Does it do more than that?
*EDIT*
I should add that all gears work fine although I do have the cold 1-2 shift issue. Once warm, everything works. I have not checked the vacuum modulator yet or adjusted bands. The trans was rebuilt an unknown number of miles ago after a fair amount of hard parts broke apart.
*EDIT*
