a4ld new modulator valve, stuck in 1st | Ford Explorer - Ford Ranger Forums - Serious Explorations
92expl0der
Houston, Texas
'92 XLT
Okay I just put in a new modulator valve on my 92. The tranny shifted fine before but now it stays in 1st gear EXCEPT if placed in 2, thats it. So I will go down to 1. then when i shift to 2, 2nd gear engages. then when i hit D (3rd) it goes back to 1st gear, same with Overdrive gear. Help?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
92expl0der
Houston, Texas
'92 XLT
Yes mine has the wheel on it. Ugh not looking foward to taking everything apart again.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Glacier991
EF Tranny Guru
Moderator Emeritus
Sacramento, CA 95827
1992 XLT
My guess is that when you replaced the modulator... you didn't remove the throttle valve (TV) spool....and it can be a b*t*h to get out... I am starting to be of the mind that a modulator replacement needs something akin to a rifle bore brush of the proper size used to clean that bore (AFTER the TV is out and prior to replacement) to avoid future sticking problems. The problems associated with modulator replacement causing problems in the A4LD are legion, and I think that may be why... just musing here. But, I don't think adjusting the modulator will do anything for you here.
92expl0der
Houston, Texas
'92 XLT
I did not know about this TV spool. Im guessing I have to take the modulator out again? Also once I get into the bore, what am I feeling for. Im not sure what a spool is much less a TV one?
I am thinking I just need to reach into the bore and pull out whatever is in there? And does this need to be replaced when i put the new modulator on or do I leave the spool off and re-install the new modulator and drive the truck without this spool thing? Im pretty lost but Im not giving up hope. I am trying very hard to avoid the transmission shop. Also is there a danger of accidentally pushing the spool causing it to drop into the tranny? Thanks for any help,,
92exp0der
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Here's a picture from Glacier991's photo gallery:
92expl0der
Houston, Texas
'92 XLT
mine doesnt have a wheel like that, its like a small screw on the end of it. And so with this spool. How do i take it out? And does it have to be replaced with a new one? Still confused. But thanks for the picture that helps alot.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Use a fine needle nose pliers, or a locking hemostat/forcepts to remove the spring, and the spool. Spray WD-40 into the bore. A fine tube brush would be a good idea to use. Don't lose the pin.
moon lake rick
New Port Richey, Florida
91 & 93 aerostar
VM spring
Looking at the pictures of the 2 VM's, only 1 has a spring ot the end of the (spool?). Is this correct? HAPPY HOLIDAYS TO ALL!!:usa::salute::usa:
BrooklynBay
Staff member
Moderator
Brooklyn, NY
