Fordexplorerguy1
- November 14, 2010
- NC
- 94 XLT 4.0 tow package?
Hi all I would like to thank all of you for your help i was able to get my ex running and A special thanks to brooklynbay as he gave me a lot of information about my a4ld. So i finally got my pan back on, I had to get thinner o rings for my new valve body got all the bolts tightened down, but now my problem is I only have Drive no Overdrive no reverse Neutral works fine and i think 1,2 work but i didnt try I was able to move my truck but i had to park it because i was low on gas, The symptoms are that i shift into OD and the rps go up instead of down and nothing happens when i put it into reverse. Also I think my modulator is bad because my atf is disappearing and my exhaust is unusually smoky. Could low fluid cause reverse and overdrive not to work? What could be the cause? Any help would be appreciated.
