RMR Motorsports
- March 9, 2012
- Kingman AZ
- 92 Ford Explorer XLT 4X4
Ok my transmission just took a dump again after it was rebuilt 7 years ago and my friend that owns a transmission shop had a performance torque converter built for me from Hughes and did all the updates and shift kit the last rebuild and this time I'm going to get a #K15 . Combo Kit. Fits A4LD transmissions, 1985 to 1994. You get an Alto master rebuild kit plus a Transgo Shift Kit, 2 large servos for 2nd and overdrive, 2 performance black carbon fiber bands, Sonnax oversize pressure boost valve and a 3rd gear clutch - Alto Power Pack that will give you up to seven clutches. This will give you one more clutch in 3rd and reverse than you have now. Stock has 4 to 6 clutches, from PATC has anyone got one of their transmission or used this kit and how did it work for you? Also on the torque converter what stall are you going with? For more info on transmission kit and transmission that you can buy I put web site below. Thanks Loren
http://www.transmissioncenter.org/a4ld.htm
I have a 92 XLT 4X4 4.0, 7.5 lift, 4:56 gears, and plan on going to 35 inch tires.
