jbsytes
- January 6, 2009
- Tacoma, Wa.
- 1994 XLT
I've searched the forum, can't find anything close to my problem.
I bought a used rebuilt tranny for my 94 Xplorer
The man said he rebuilt it, but pinched a seal or something like that.
So I took it to a mechanic my father recommended.
He said it just needed a "Hard Rebuild" (Bearings, Bushings, Clutch Plates, etc
I get it back, stick it in, and, Starting with nary a quart of fluid in it. put 4 quarts of fluid in, start it up, run through the gears R, D, 3, 2, 1, 2, 3, D,R.
I felt it go into all the gears, so with engine still idling, started adding one quart at a time, going thru the gears after each quart.
After the second quart, I couldn't feel it going into Reverse anymore, but It would still get Foward gears.
So I continued until the tranny read full on the Dip.
Still no reverse, but when I applied some throttle, while in reverse, it acted like it wanted to go, and after several 4500 rpm revs, it started to back up, but like it was doin so in a pile of mollasses. Foward gears no problem.
Reverse nada.
Any tips, Ideas, suggestions, theorys, or fixes greatly appreciated.
Thanks.
Reverse nada.
Thanks.
