A4LD Questions/Problems/Recommendations | Ford Explorer Forums - Serious Explorations
disvnvet
Sacramento, California
I really want to make sure that I repair the right thing on my
Transmission so I am posting this AGAIN. It is a A4LD on a 1994 Ford
Explorer 4X4.
I am not questioning the expertise on the forum however, with mixed
responses from multiple sources, I want to verify before starting the
project.
I have been told that the problem is:
1. The Governor
2. Could be the Torque Convertor
3. Although not likely, it could be the Modulator.
Situation:
I recently installed a 1992 A4LD transmission that was recently
rebuilt: I don't know if the Torque Converter was replaced at that
time. The only difference between the one removed and the new one is
the Modulator. The original Modulator was not adjustable and the one
on this transmission is.
When the vehicle is cooled down, it intermittently is reluctant to
shift i.e. It will start out in first but seems to lack power. The
same is true when it is cold however, it is not intermittent, it simply
lacks go-power. It takes more RPM than normal. It slowly shifts to
second, third. I can punch it and force it to shift although not
always successful. If it does shift it will then shift normally until
it sits for a little while and has the opportunity to cool down.
If I warm up the vehicle to normal operating temperature before
driving, the transmission will shift normally. One again, it may or
may not shift correctly when it has the opportunity to cool down a
little.
Only thing I noted beside this is:
When I open the hood, when cold, I hear what appears to be a vacuum
leak in the area of the EGR Valve. To be honest with you, I don't know
if this is normal. I don't fully understand how the vacuum is created
so any input in this area would also be helpful.
What I have learned is:
1. I know how to replace the Modulator and watch for the pin.
2. I also know how to replace the Governor however, "Whatever It
Takes" Transmission parts (WITTrans.com) lists a number of Governors so
I have been told to remove the old one and identify which is installed.
This is questionable from my perspective since I have to literally take
the transfer case off, remove the govener, and order and wait for a
replacement.
3. It has also been recommended that I replace the 30mm Weight with
the Sonix 35mm weight.
I am willing and capable to do all that is recommended however without
confirmation I am hesitant for the following reasons:
1. If the governor will cure the problem great however, If it is not
the governor I will have wasted my time and had a lengthy down time
waiting for the part.
2. Additionally, if it is not the governor and it turns out to be the
torque convertor I will have to do the same process again but have to
remove the tranny on top of this.
3. I have not mentioned the modulator since I am going to replace that
regardless.
What I am asking for:
Confirmation of what I need to replace before I begin and/or the
procedure to verify the problem before I tear it down. Additionally,
if someone can verify which governor to order without first removing
the one installed would be of significant assistance.
Thanks In Advance.
hey there. if you hear a vacuum sound near the 'octopus', then check that all the hoses are connected. feel the ends of the hoses, or look, and see if there's fluid or wetness. if so, that's transmission fluid from a break in the modulator valve. does your transmission need fluid? check that while hot, cause it may be losing it through the broken valve. also, when you start the car, the fluid may blow the hoses off, with fluid splatter. i'm about to change my valve after i get my starter question answered.
A4ld Problem.
I just sent email to WIT.
I have checked the vacuum lines and not found any problems or wetness however, I will check again.
Fluid level is fine.
Will let you know tommorrow if I find anything.
Thanks for the help.
A4ld Problem.
Could not find any vacuum leaks. I still need to get under the car but rain and cold is holding me up.
Called WIT. They couldn't tell me which govenor to use. They tried to connect me to Steve Atwell but no answer.
Will call again on Monday.
Had another person contact me and they said it might be a servo inside the tranny.
Add more confusion to the fire. For now, I am going to stick with the vacuum and govenor.
