Yankee516
- May 28, 2010
- Long Island, NY
- 94 XLT, 99 5.0L AWD
Hi Folks,
Into my first A4LD rebuild and ran into my first problem. Tranny is out, but can't seem to remove the two studs that also hold the retainer for the gear shift cable. When I turned the nut on the top, the stud came with it and now it is kind of bound up.
The retainer can't move up to provide room for a wrench since it wraps around another stud in the extension housing that holds it (the area between the two circles in the first photo below).
At this point, I'm stuck since the stud bolds don't provide enough room for an open ended wrench to turn the stud:
Not sure if the studs are only screwed into the extension housing or if they pass into the case, in which case the extension housing is just REALLY tighly held to the case. I don't want to risk any damage and hope that someone can provide some assistance so I can tear into the guts tomorrow.
THANKS IN ADVANCE!
--Phil
THANKS IN ADVANCE!
--Phil
