A4LD scheeches then jumps into 1st gear | Ford Explorer Forums - Serious Explorations
kraylake
my 92 a4ld was popping into reverse, i changed the reverse servo orings, no help, i instaled a recomended reverse servo extender and that helped.
It was not shifting into OD, i installed a modulator value, that helped.
Now when cold when u put it into D u have to rev it a bit to get it into gear, it gives a audible screech then pops into low.
What can i do?
Have you flushed the fluid? If not I would have it flushed and a new filter installed. There may be crap that necks down the passages in the tranny. The fluid being forced through may make a screech. Like pinching a garden hose.
Back flushing with a cleaner and new fluid may clean that stuff out. Chances are though that if its that bad inside, your trans may be worn out requiring a rebuild anyway.
