TN_Explorer
- October 27, 2004
- Manchester, TN
- 5-1991's; 1-94; 1-2000
Here's my sad tale of woe. Son used the 1991 Explorer to tow his girlfriend's car; transmission was extremely low on fluid and he got it hot & black, then gave it back to me.
It wouldn't shift into forward gears; only had reverse. I drained it, put a new filter and a jug of transmagic in it and it now has all gears, sort of:
Reverse is fine. Going forward there is about a 5-second lag, then it drops into gear. It pulls strong and shifts properly up through the gears including OD, and when you let off the gas it's as though you shifted into neutral. Slow to a stop and you can repeat this as many times as you want.
Pulled the valve body, but it was surprisingly clean and there was only one possibly hanging valve.
I don't find anything on this weird type of behavior. Any ideas while I have it apart? I really don't want another ATF shampoo if I can avoid it.
Thanks,
-- Mike/Tennessee
Thanks,
-- Mike/Tennessee
